steering column
Old May 31, 2009 | 08:20 PM
jrd1990zr1's Avatar
jrd1990zr1
Default steering column
While repairing the horn contacts on my 1990, I noticed what appears to be some side play with the column. Possibly from a previous owner pulling on the wheel toward the 8:00 position. Any one else experience this problem or aware of how to make a repair?
Thanks, John
Old May 31, 2009 | 09:17 PM
jimmers's Avatar
jimmers
This is a very common problem, I just fixed mine the other month. Here is a great site with a walkthrough. http://domesticmisfits.net/forums/viewtopic.php?t=124
You might get lucky and just need to tighten the 4 torx bolts. If not you will most likely need to replace the housing because the pivot pin holes are worn. You can get a used housing from a junker, or you can buy new. I got all new parts from this site. http://www.corvettesteering.com/index.html Tom Reina is very helpful!
