Engine Cleaning Help
Old Jun 5, 2009 | 01:50 AM
samsonb's Avatar
samsonb
Originally Posted by CopperCorvette
Here are a couple of before and after pics.
Let the members give or
What did you use to clean the back of your hood, control arm area, and in the engine bay? And what dressing did you put on? It looks really good.
The backside of my hood needs a good cleaning and detailing:
And I've got paint overspray on my wheel wells from the PO. So, I'll have to figure out how to get that off. Maybe paint thinner?
Old Jun 5, 2009 | 01:53 AM
samsonb's Avatar
samsonb
Originally Posted by CStewTAMU
What I have found works great on black plastic is the turtle wax ice car wax. It makes the plastic look new, not greasy or wet like CD2 can.
That CD2 stuff will hide dirt on a dusty engine, but it won't be a clean "dry" look. It's basically an Armour All for engine bays.
Thanks for the headsup. All I've heard is good things about the CD2. But I would like a good clean dry look vs. a clean wet look.
If you touch a plastic part that has that CD2 on it, does it come off on your hand?
And what are you using to dress your hoses and other rubber parts?
Old Jun 5, 2009 | 02:04 AM
CopperCorvette's Avatar
CopperCorvette
First I used regular engine degreaser of the wheel areas and did the rest with this
Then I used the CD2. It dries just fine and "NO" it doesn't get all over your hands. It lasts for months.
Old Jun 5, 2009 | 07:01 AM
frenchyoliver's Avatar
frenchyoliver
steel whool double zero with a cheap heavy duty degreaser + hot water.
Old Jun 5, 2009 | 07:37 AM
ThomasRetUSN's Avatar
ThomasRetUSN
Originally Posted by larry00
Thomas what do you use on the black plastic ?
Most stuff doesn't last very long !
You are correct most stuff does not last. What I do after I have everything clean (water and elbow grease) I just wipe everything down with armor all and buff. Lots of work but the best way I know to make it look good.
Old Jun 5, 2009 | 07:43 AM
ThomasRetUSN
Originally Posted by Japicella
Thomas, that does look nice-not overly done.
BTW, are they stock wheels? I don't recognize the tire tread with anything available for our year.
No they are 275x40x17 Sumitomo HTRZ II with 9.5in ZR1 wheels. I have had them three years, wear great, no road noise and look good.
Old Jun 5, 2009 | 12:38 PM
Red-Lt1's Avatar
Red-Lt1
I wipe the entire engine compartment and the inside of the hood down about once a month. It doesn't take that much work if you keep up with it.
Old Jun 5, 2009 | 08:20 PM
CopperCorvette
I've been looking at your pics close up. Are you sure that white stuff is paint? The underside of the hood has spots that look like it was left after something evaperated away. Do they use salt or deicer on the roads where you live? I would think even if it is paint in your wheel wells you would be better off swapping out the inner splash guards. That would remove more than 90% of the work and would look great. Copper
Old Jun 6, 2009 | 05:40 AM
samsonb's Avatar
samsonb
I think the spots under the hood were that way when I bought it a couple of years ago. What would be good to clean that off without damaging the paint under the hood?
Those spots on the wheel wells is chips in the paint. The PO had the car repainted. It does look a little worse than it did as a year ago, I sprayed some bug and tar remover on it and power washed it, and that caused more of the paint to chip off. I'd like to just strip the paint off and then see what it looks like. If it still looks crappy, then I may paint it with something that is rock chip resistant. I could swap them, but that would be several hundred, as also the wheel wells on the hood is in the same condition.
Old Jun 6, 2009 | 07:10 AM
Paul Workman's Avatar
Paul Workman
Default Just one word...WOW!
This is what I have done on my 86 Coupe. I use quad zero steel wool, scotch bright and Mother's Alum & Mag polish plus a lot of work but in the end it will pay off.
And thanks for the tips!
P.
Old Jun 6, 2009 | 11:35 PM
CopperCorvette
Have you tried anything on the spots yet. Give me a list of products that way I'll have an idea what won't work. I could name off tons of products, but by not seeing the car in person....yada yada yada, Copper
Old Jun 7, 2009 | 01:47 AM
samsonb's Avatar
samsonb
No, I haven't tried anything. I say it will come off easily as there is similar small white spots in the engine compartment that rubs off. Like around the injectors, compressor housing, etc. Probably salt I guess, I did drive it some in the winter.
I just didn't want to use something that would damage the paint.
Old Jun 7, 2009 | 04:12 AM
  #33
CopperCorvette
If it is salt try using "Salt-Away". It's a marine product use on boats. Once you get the salt issue under control you'll be fine. Copper
Old Jun 7, 2009 | 06:28 AM
  #34
samsonb's Avatar
samsonb
Though, what would be used to clean the back side of the hood? I'd like to clean it, but not ruin the paint.
Old Jun 7, 2009 | 08:13 AM
  #35
CopperCorvette
Salt-Away comes in a 16 oz spray bottle. Spray, wipe and then rinse off your hood.
Old Jun 16, 2009 | 10:19 PM
  #36
samsonb's Avatar
samsonb
Thanks. What do you normally use to clean the back of the hood?
And any recommendation on what to use to strip paint off of plastic?
Tommorrow I'll start on cleaning the engine bay. I've got aluminum safe Simple Green for my degreaser and general cleaner. I'll have wrags, tooth brushes, wheel cleaner brushes, etc. to try and clean most of the gunk off. The worst is the front of the engine, caked on black grim.
I've got me a flexible water blaster that will help some. And for what grease I can't reach and get all the way off, I'll use some brake cleaner.
Old Jun 16, 2009 | 11:42 PM
  #37
lostnfoundC4's Avatar
lostnfoundC4
Josh,
I have few white spots on the back side of my hood too but haven't attemped to clean it up yet.
I had black undercoating sprayed overtop of road dirt on my upper and lower fender wells. I found good old Brake-Kleen, a scotch pad, and a little elbow grease cleaned them up pretty good. I applied a few coats of Meguiar's Natural Shine to the uppers and it looks like new and use this stuff on my tires too. It doesn't last as long as the glossy stuff but IMO looks better.
I still have the driver's side to do yet-too much rain here in MD = to much yard work this spring. I wish it meant more garage time to get more detailing done!
Old Jun 17, 2009 | 01:22 AM
  #38
samsonb's Avatar
samsonb
Josh,
I say I'll probably end up just trying regular car wash with a sponge on the back side of the hood and see what that does.
I'll try the brake clean on the fender wells. But I say mine will be a little harder as it has multiple layers of paint vs. undercoating out of a can. I may try a Urethane safe paint stripper. I say that is probably the safest stripper.
If they still look like crap, I may have them sprayed with that rhino lining or something.
