I have a '89 that I purchased last fall, but the head lights don't seem to raise right. I had heard that the gears that are driven by the solenoid are replaceable rather than all new units. Is this so for the c4 or only other models?
TIA
If the motor continues to run, the headlights 'bounce', and you hear clicking noises then the bushings are worn out. Easy fix.
I am having the exact problem that you are describing with my 85, I looked for headlight bushings at Ecklers but could not find the part, could you point it out for me?
