c4 problems
Old Jun 16, 2009 | 12:24 AM
loucazo's Avatar
loucazo
Default c4 problems
On a hot day after driving my car for about an hour it starts to run bad looses power sputters when you hit the gas peddal. Seems to run fine at night when it is cool out. It's a 1994 coupe. Anyone have any ideas?
Old Jun 16, 2009 | 09:58 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Ignition module or coil
Perhaps the opti
did you pull the codes yet?
Old Jun 16, 2009 | 10:01 PM
larry00's Avatar
larry00
Check your Water Temp .
Overheating will make it do the same thing.
Check fuel pressure too .
Clogged Fuel filter could be the problem .
Old Jun 16, 2009 | 11:10 PM
loucazo's Avatar
loucazo
I have it in the shop now they say tune up and opti, and while they are there waterpump too. I changed the fuel filter last oil change, it does run a little warm tho. Well hope they fix it. Ty for the replies.
Old Jun 18, 2009 | 11:28 PM
loucazo's Avatar
loucazo
Default Still no fix.
Well changed the opti, did a full tune up but the car still runs the same , now at an idle or stoped at a red light the cars idle will spike up on it's own.
Old Jun 18, 2009 | 11:30 PM
NitroNutt's Avatar
NitroNutt
Vacuum leak
Old Jun 19, 2009 | 12:29 AM
Frizlefrak's Avatar
Frizlefrak
They need 3 things to run correctly, and three things only;
1. The correct mixture of fuel and air.
2. A sufficiently strong spark delivered at the correct time.
3. Sufficient compression.
That's it. If those 3 conditions are met, they run correctly. If one is missing or deficient, they either run incorrectly or not at all. Your job is to narrow down which one is the culprit, and then figure out WHY it's the culprit.
We can probably eliminate #3 right off the bat if your car runs fine when it's cold. With bad compression, it either would run poorly all the time or not at all. Which leaves us with #'s 1 & 2. The emissions systems affects both of these as well.
Sooo....it's time to run some tests. Troubleshoot, DON'T GUESS. Don't throw parts ($$$) at the car trying to fix it unless you're independently wealthy and have nothing else occupying your time. If you approach it methodically, you WILL find the problem and be able to rectify it. I've never had one I couldn't get to run correctly.
Let's start with #1. What is your fuel pressure? Check with a guage on the schrader valve. Tape it to the windshield and drive the car. What is the pressure when an event (running poorly) takes place?
Post the results of that test and we will go from there.
To c4 problems
