Need a Connector Part
Old Jun 19, 2009 | 10:51 AM
JAKE's Avatar
JAKE
Default Need a Connector Part
I'm doing a head and cam swap on my son's Vette. Old age and brain-deadness caused me to forget to unplug the Oil Pressure Sender/Fuel Pump Switch connector before pulling his 96 LT1 engine. It's the unit mounted on the rear China Wall; thE tall black-colored one.
So naturally the connecor wires broke and I've been trying to find a pigtail replacement connector, with no luck. Ive called Ecklers, Mid-America and Corvette Central and even checked GMPARTSDIRECT; but no good.
The Sender/Switch is fine, I just need the connector with the pigtail wires so I can splice them into the car's wiring harness.
Does anyone know the part number and/or where I can find one?
Any info will be greatly appreciated.
Thanks,
Jake
West Point ROCKS!
Old Jun 19, 2009 | 11:01 AM
jimg's'93's Avatar
jimg's'93
Looks like EFI may have your part:
http://www.eficonnection.com/eficonn..._pigtails.aspx
Old Jun 20, 2009 | 01:32 PM
JAKE's Avatar
JAKE
Originally Posted by jimg's'93
Many thanks for that link. I found one that looks like what I need and I ordered it today.
Jake
West Point ROCKS!
Old Jun 20, 2009 | 11:34 PM
jimg's'93's Avatar
jimg's'93
Hope it works out
Old Jun 20, 2009 | 11:58 PM
WVZR-1's Avatar
WVZR-1
JAKE,
You shouldn't have needed EFI, Ecklers or any other "mail order" source. A local NAPA or "most" other auto parts retailers in the your area should have been able to help you. A local dealer for sure could help!
If you've got any "doubts" about your "choice" from EFI you might cancel and do the connector "locally"!!
Here I believe is the switch "you" mention (10201491): http://198.208.187.182/internet/View...umber=10201491
This I believe your connector (12085499) (ACD PT121): http://198.208.187.182/internet/View...rtNumber=pt121
If those are "you" take those #'s to an auto parts place "locally"!!!
To Need a Connector Part
