service engine soon light on
Jun 22, 2009 | 02:28 AM
I have done a forum search and no answer.
On a 1987 C4 how do I reset, turn off, the "Service Engine Soon" light?
Been on for a year now and finally getting to me
Jun 22, 2009 | 04:59 AM
You need to check for the code that made it come on, but to turn it off or clear the codes disconnect negative battery cable for a couple of minutes, but if the problem is still there it will come back on.
Jun 22, 2009 | 05:15 AM
Quote:
Originally Posted by
floridamale
Jun 22, 2009 | 07:05 AM
eylesda
Pull the code, fix the problem, then disconnect the battery for 10 minutes.
Ground A and B with paper clip, turn key on, and count the flashes as described
HERE Write down any trouble code(s)
Now go here and fix the problem(s).
Trouble Codes
Jun 22, 2009 | 07:39 AM
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
no reason to pull battery cable.
Just take the ECM fuse out for a few minutes.
Jun 22, 2009 | 11:03 AM
Just stick a piece of tape over it. YGBSM!!
eylesda
Jun 22, 2009 | 11:48 AM
MK 82
This is not really a answer
Jun 22, 2009 | 02:16 PM
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Joslinm
When the SES light came on in the '88, it was a loose connection on the EGR pigtail.
Jun 22, 2009 | 02:27 PM
Neither is ignoring it for a year.
floridamale
1986 ,
1987 ,
1996 ,
c4 ,
corvette ,
engine ,
light ,
reset ,
service ,
turning ,
vettte
