Common problems with Vettes?
Old Feb 10, 2002 | 12:54 PM
blackbelt's Avatar
blackbelt
Default Common problems with Vettes?
What are common problems with say a 94 Vette, and what are typical maintnance cost for one.(ex. Tune ups, and any other thing that they may typically need or have problems with.)
Old Feb 10, 2002 | 01:26 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Common problems with Vettes? (blackbelt)
Depending on miles, you got the waterpump and Optispark, I changed both at 76,000 miles, some go longer some a little shorter.
Brakes, especially fronts.
Usually the rear tires are more worn.
Clutch, wheel hubs/bearings, u-joints.
None of these are a big worry unless over 50-60 thousand miles.
Old Feb 10, 2002 | 01:27 PM
Bones LT1's Avatar
Bones LT1
Well, common problems with a Corvette are the about the same as with any car. My car a 1993 with 94k in the last 6 months I've replaced the battery.
$55.00.
Last week I had the oil changed and the plugs changed. I brought the oil and the plugs to a shop and the labor for the work was $90.00.
I replaced the serp belt myself but I had to make a tool to do it.
The belt was $50.00 GM only.
The opti-spank is a common problem with LT-1's. The engine pulley must be removed to replace it, but it unbolts so it isnt all that hard to do.
Old Feb 10, 2002 | 01:52 PM
Drewdog's Avatar
Drewdog
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Common problems with Vettes? (Bones LT1)
The only problem my car had when I bought it (At 55k miles) was the weatherstripping was worn, and it would leak a little under heavy rain. Other than that no problems, cept for extra attention from the cops :D
[Modified by Drewdog, 12:53 PM 2/10/2002]
Old Feb 10, 2002 | 02:05 PM
vettlesstintguy's Avatar
vettlesstintguy
Default Re: Common problems with Vettes? (Drewdog)
i have heard some lt1`s have a oil leak problem around the back of the intake manifold, the only reason i bring that up is it happened on my 93 formula and since then probing the boards i have seen that talked about as "the dreadded lt1 oil leak", i got rid of the car, and said i would never have another lt1 car but i`ll be damned if i`m not looking for one right now, this time a vette mabey its just a prob in the camaros, transam, and formulas. i still hava a nasty oil stain in my garage, my formula had 67 thousand on it when it happened.
To Common problems with Vettes?
