coolant flush?
Old Jun 24, 2009 | 08:41 AM
RR40vette's Avatar
RR40vette
Default coolant flush?
I have a 93 lt1, anyone here tell me the proper way to flush the coolant system?
Old Jun 24, 2009 | 02:48 PM
kenmack's Avatar
kenmack
Default carefully
1993 Ruby LT1 8200 mi.
Remove rad cap / open rad drain / remove knock sensors at oil pan.
Stuff lotsa rags between water pump /opti spark distributor and block.
and gently,low pressure flush system until running clear.
Open bleeder valves at thermo housing both sides and refill until full,close bleeders as soon as possible.
Did this with mine and had virtually no air bubbles and didn't even have to top it up later
Old Jun 24, 2009 | 06:45 PM
RR40vette's Avatar
RR40vette
remove knock sensors at oil pan? have a pictures of knock sensors? can't do it with them on?
Old Jun 24, 2009 | 11:22 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
remove the KS shields
disconnect KS
place a container underneath the KS
using a 22mm socket, remove both KS
you'll get better drainage if you let the car rest at normal height
If you choose not to remove the KS, you'll only flush the radiator and hoses. Most of the "junk" rests at the bottom of the block.
Take the time and do it right
Old Jun 25, 2009 | 08:51 AM
RR40vette's Avatar
RR40vette
ok where do you hook the hose up to?
Old Jun 25, 2009 | 09:54 AM
PLRX's Avatar
PLRX
2017 C4 of Year
You don't need a hose, let gravity do it's job.
The hoses I spoke of are the car/engine coolant hoses, if the Vette is in an angle the heater core and tank will not drain.
Old Jun 25, 2009 | 06:37 PM
RR40vette's Avatar
RR40vette
knock sensors at oil pan? does anyone have a picture so i know what to look for?
Old Jul 7, 2009 | 10:04 PM
RR40vette's Avatar
RR40vette
I was under the car the other day, going to flush the coolant out, I think I found the knock sensor it's on the left side just above the oil pan about middle, this right? Is there another knock sensor other than that one? When I pull it out and reinstall it should use any type of sealant, on the threads of the knock sensor? I don't want it to leak!
Old Jul 8, 2009 | 11:18 AM
MK 82's Avatar
MK 82
My 96 LT4 has two. Not sure what year they added the second one. May be an OBDII thing.
Old Jul 9, 2009 | 05:20 AM
RR40vette's Avatar
RR40vette
bump
Old Jul 9, 2009 | 05:41 AM
94z07fx3's Avatar
94z07fx3
bump
There are two KS, one either side. They screw into the block about in the center just above the oil pan. Can't miss them once you're under there.
Old Jul 10, 2009 | 05:28 AM
RR40vette's Avatar
RR40vette
when i reinstall the knock sensors it should use any type of sealant, on the threads of the knock sensor? I don't want it to leak!
Old Jul 12, 2009 | 05:04 PM
RR40vette's Avatar
RR40vette
Thanks for the info.
Drain the rad. / remove the two knock sensors. Bought some peak coolant, and distilled water, mixed 50/50 filled and open bleeder valve on housing it seemed to have no air! Easy job
Old Jul 14, 2009 | 09:21 PM
garyssgary's Avatar
garyssgary
Whatever you do or how you do it, replace the stat and try to clean the radiator. See other threads related to that. I flushed my system and it increased coolant temp to the 230s. It turned out the stat and cleaning radiator outside was the trick.
To coolant flush?
