Spark Plug question
Old Jun 28, 2009 | 03:06 PM
littleyellowvette85's Avatar
littleyellowvette85
Default Spark Plug question
Would anyone be able to help me w/ figuring out the spark plug gap for '85 Vette ?....Right now I bought some auto lite plugs and they are all gapped at .045. Will that be fine?..Thanks, jess.
Old Jun 28, 2009 | 03:11 PM
samsonb's Avatar
samsonb
The gap is .035 on my 89. I say that is the gap for yours as well. My 89 Firebird is .035 as well. I think that gap is too high, go to .035.
I believe yours has iron heads, make sure you have the right plugs. The aluminum plugs are longer on the threads and have a metal washer on them.
Old Jun 28, 2009 | 03:41 PM
littleyellowvette85
Thanks Josh, I just bought some MSD street fire plugs w/ AutoLite. I think I will take em down a little. Jess
Old Jun 28, 2009 | 05:14 PM
slim jim 2's Avatar
slim jim 2
1984 .045 1985- 91 .035
Old Jun 28, 2009 | 11:50 PM
littleyellowvette85
Thanks Slim, all gapped to .35 and installed. I tell ya, w/ my fat little paws that # 6 and #8 plugs were a pain !!!...Thanks for all the help
Old Jun 29, 2009 | 12:51 AM
samsonb's Avatar
samsonb
Just wondering why you chose Autolite? I put in AC Delco plugs in my 89, and after a month I was looking around and noticed the base of the plugs had rusted. I was told this was normal because of the material they are made of. Though, the PO gave me the original AC Delco plugs in a box, and they weren't rusted.
I'm gonna replace them again with a different brand as I don't like the look of rusted plugs. I took a few out, and the threads were fine, but I still don't like it.
I was thinking of going with NGK as it gets good reviews.
Old Jun 29, 2009 | 01:51 AM
yaknow's Avatar
yaknow
Josh,
I"ve been told the NGK plugs burn hotter than the Delco's and can cause damage to your pistons. I don't know if this is true or urban legand but, you may want to reconsider this option.
Old Jun 29, 2009 | 06:35 AM
84camino406's Avatar
84camino406
Originally Posted by yaknow
Josh,
never had a problem with NGKs at all. run them in my 400 now, turning it 6400 @ the track. ran them in my sportsman headed 350 years ago too. just get the correct heat range for the application and roll. plus they are as short as the "shorty" plugs that are twice the cost! had good luck with them in a nutshell.
Old Jun 29, 2009 | 11:50 AM
littleyellowvette85
Josh, I choose Autolite because that is what I had in stock at my job. LOL.. Its either autolite, a/c delco, or champion. Jess.
Old Jun 29, 2009 | 02:20 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I'm running NGK TR-55 Double Platinum in my LT1 with no problems at all. In fact, I'm very happy with them.
Old Jun 29, 2009 | 02:33 PM
samsonb's Avatar
samsonb
How are the copper NGK plugs? It seems alot here who run the NGK plugs are running Platinum or something like that.
Old Jun 29, 2009 | 03:27 PM
ejscarfo's Avatar
ejscarfo
The gap in the early 85's were .045 and then they were changed to .035. Check to see if you have a sticker on the driver's side top of the radiator noting the change. I read some TSB about a change in the HEI distributor back in the day.
Old Jun 29, 2009 | 04:34 PM
coco1950's Avatar
coco1950
I am running NGK Platinum on my 89. No problems, very happy with them.
Old Jun 30, 2009 | 11:28 AM
onedef92's Avatar
onedef92
The copper is OK, but just won't last as long. Even with its clamshell hood, a plug swap is not something you wanna do every 12,000 miles in a C4.
Old Jun 30, 2009 | 03:36 PM
samsonb's Avatar
samsonb
Why would you have to do it every 12K miles? I think the original plugs on my 89 Firebird went for 80K miles before I changed them. It is now over 160K.
I was just wanting to make sure there wasn't something wrong with NGK Copper plugs, as everyone here seems to use the platinum. Sometimes companies make good and bad products.
So, I which do you think would be better for an 89, copper champion plugs, or copper NGK plugs? I would have liked to stay with copper AC Delco, but I don't like how they rust up for some reason, even though the original plugs don't rust up. They must have switched to a different manufacture since then, and the metal they use rusts up unlike the plugs from a couple of decades ago.
Old Jul 1, 2009 | 08:33 AM
Phantom_Vette1's Avatar
Phantom_Vette1
i have always thought of NGK for my other cars as being a very good plug!
i will be trying these for the vette next!
To Spark Plug question
