Engine code H43
Old Jun 28, 2009 | 09:51 PM
kylebuck89's Avatar
kylebuck89
St. Jude Donor '09
Default Engine code H43
Does any know what that code stands for?
Old Jun 28, 2009 | 10:26 PM
nada1's Avatar
nada1
Not sure but i think it is for the knock sensor circuit
Old Jun 29, 2009 | 12:24 AM
formul89's Avatar
formul89
My '94 would come up with that code intermittently. I replaced the left bank o2 sensor because it was really rich from that side and the code has not come back since.
Old Jun 29, 2009 | 06:40 AM
floridamale's Avatar
floridamale
1985-1991: ECM Codes
Code #12: Normal No Codes.
Code #13: Open Oxygen Sensor Circuit.
Code #14: Coolant Sensor Circuit Low.
Code #15: Coolant Sensor Circuit High.
Code #21: Throttle Position Sensor High.
Code #22: Throttle Position Sensor Low.
Code #23: Manifold Air Temperature Circuit High.
Code #24: Vehicle Speed Sensor.
Code #25: Manifold Air Temperature Circuit Low.
Code #32: EGR System Failure.
Code #33: Mass Air Flow Sensor High.
Code #34: Mass Air Flow Sensor Low.
Code #36: Mass Air Flow Sensor Burn-Off Function Fault.
Code #41: Cylinder Select Error.
Code #42: Electronic Spark Timing.
Code #43: Electronic Spark Control.
Code #44: Lean Exhaust indication.
Code #45: Rich Exhaust Indication.
Code #46: Vehicle Anti Theft Fault.
Code #51: Faulty Mem-Cal.
Code #52: Fuel Calpak Missing.
Code #52: (1990-91 Corvette Only): Engine Oil Temperature Sensor Low.
Code #53: System Over Voltage.
Code #54: Fuel Pump Circuit Low Voltage.
Code #55: Defective ECM.
Code #62: Engine Oil Temperature Sensor Circuit High.
To Engine code H43
