new battery
Old Jun 28, 2009 | 10:06 PM
carl ford's Avatar
carl ford
Cruising
Default new battery
Turns over, does not fire ,1986 CAR RUN GREAT BEFORE REPLACING BATTERY
Old Jun 28, 2009 | 10:43 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
Little more info might get a reply.. Start with year??
Old Jun 28, 2009 | 10:50 PM
jfb's Avatar
jfb
Engines require spark and spark at the right time, fuel and air and in the right ratio in order to start and run. Use a timing light while someone cranks to see if you have spark and spark at the right time. Use a fuel pressure gauge on the shrader valve at the end of the right fuel rail to see if you have correct fuel pressure (36-42 psi). Then see if the pressure holds for a long time ign off. Rapid loss of fuel pressure can be caused by leaky injector/s or a defective check valve in the fuel pressure regulator. Use a noid light (available at parts stores), or an LED with a 680 ohm series resistor on an injector plug during cranking to see if the injectors are being pulsed. The LED must be connected with the correct polarity.
Old Jun 28, 2009 | 10:53 PM
captmike13's Avatar
captmike13
Cruise-In IX Veteran
Try this out. Very good reading and explains the start up sequence. without info on car yr it is hard to help you out.
http://www.corvetteactioncenter.com/...4/016/article/
Old Jun 29, 2009 | 08:37 AM
carl ford's Avatar
carl ford
Cruising
Originally Posted by ccrazor
little more info might get a reply.. Start with year?? :d
1986 run great before replacing battery
Old Jun 29, 2009 | 08:42 AM
carl ford's Avatar
carl ford
Cruising
1986 car run great before replacing battery
To new battery
