Early C4 dash (breadbox) replacement
Old Jun 30, 2009 | 12:42 PM
FrankN's Avatar
FrankN
Default Early C4 dash (breadbox) replacement
I've done a search but can't seem to find anything although I know this topic must have been discussed before. I'm replacing the dash (bread box, actually it's the map pocket) for the streamlined dash kit from Corvette Central. Anyone have any pictures of how it looks installed? Easy to do?
Thanks!
Old Jun 30, 2009 | 01:16 PM
takovr's Avatar
takovr
Very easy to install I got one from Ecklers, it comes with 2 sided tape but I used screws to install it.
Old Jun 30, 2009 | 03:58 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Do you intend to keep your original pad? If not, I found it a whole lot easier to just cut the damn thing off,
and access the factory screws from the backside. 10 minute job once I said, eff it, and started cutting. BTW, I used 3/M double-sided tape instead of the cheaper stuff that comes with the kit.
Old Jun 30, 2009 | 06:00 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
I regret cutting mine out of my 87. The guy I sold it to is trying to return to original. When he takes my home made flat panel off to replace the breadbox he is not going to be happy with my butcher job.
Old Jun 30, 2009 | 07:52 PM
'Shifter's Avatar
'Shifter
NCM Member '09
I wouldn't do it to a car where restoration is a possibility....
Old Jun 30, 2009 | 10:47 PM
jackdk's Avatar
jackdk
Thanks!
FrankM, I put one in mine. It looks great, I think. If you PM your email address, I'll send you a picture.
Old Jul 1, 2009 | 04:11 AM
lil_Mike's Avatar
lil_Mike
heres mine closed and open. i bought it from my local vette guy. guess it was on a vette he parted out. looks like a custom piece. i wrapped it in vinyl and painted it all black.
Old Jul 1, 2009 | 07:17 AM
jeffp1167's Avatar
jeffp1167
seen some guy sometime back that had a fully functional glove box in place of that thing. might a been on CAC not sure or maybe here.
Old Jul 1, 2009 | 10:56 AM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
I'd leave the "breadloaf" alone. It's part of the early C4's character (I'm a originality freak).
Old Jul 1, 2009 | 11:06 AM
65747785's Avatar
65747785
I agree with these guys.
Old Jul 2, 2009 | 09:34 AM
mgafun's Avatar
mgafun
Here it is. No longer made (was made in CA originally)
The cup holders in the lid do work well:
And what's behind it (prior to install, note that the dash pad had to be removed):
Old Jul 2, 2009 | 06:34 PM
RickSnow's Avatar
RickSnow
Andrews Woodworking Design in Michigan used to make a fully functional glovebox in various imitation wood grains....to replace the "Breadloaf".... I took it out a while ago....I still have it in the basement somewhere.
To Early C4 dash (breadbox) replacement
