PLZ help!
Old Jul 3, 2009 | 11:24 AM
ARMAN72's Avatar
ARMAN72
Default PLZ help!
I went out to take the Vette to pick up my son and it wouldnt start! It cranks and turns over but wont start! I last drove it on Sunday! A few weeks ago I posted that when i went to drive it it flashed sys by the speedo and someone said it was the battery but never done it again after that one time! Do i need a new battery or what..Like i said it cranks and the lights and everything comes on please help!
Old Jul 3, 2009 | 11:28 AM
pologreen1's Avatar
pologreen1
check your battery with an voltmeter, but if it cranks strong that is strange.
put, a charger on it and try it, or jump it if it starts go buy a battery
are you getting fuel to the motor?
Old Jul 3, 2009 | 11:38 AM
Jon Hekking's Avatar
Jon Hekking
Could be a battery, I would try that first. It sounds more like an open ignition circuit, due to either an ignition module issue or a alarm system issue. You'll need to check the codes. Same thing happened to my 93, it was fine one moment and would only crank the next. Mine was a control module causing an open ignition circuit error. In the parts business so it was no issue...........
Good luck.
Old Jul 3, 2009 | 11:48 AM
rich653's Avatar
rich653
Just a guess but could be the resistor in your key for the vats system, if you have a spare key give it a try and see if it helps, could also be the ign switch, try the different key first. If it cranks it's not the battery.
Old Jul 3, 2009 | 11:51 AM
ARMAN72's Avatar
ARMAN72
I just tried to jump it off my other car still just cranks no start!
Old Jul 3, 2009 | 11:53 AM
jimg's'93's Avatar
jimg's'93
If it were the VATS system, there would be no crank at all.
Ensure you're getting spark and if so, check for fuel pressure.
Old Jul 3, 2009 | 12:01 PM
ARMAN72's Avatar
ARMAN72
Ok i am new to all this how do i check for a spark and fuel? I could smell gas when i was tryin to start it.
Old Jul 3, 2009 | 01:50 PM
floridamale's Avatar
floridamale
Checking spark is easy pull the #1 plug wire stick a screw driver in it place about a inch away from exhaust crank motor see if it sparks. For fuel pressure you will need a gague on the fuel rail
Old Jul 9, 2009 | 06:59 PM
ARMAN72's Avatar
ARMAN72
Ok I had it towed today to the shop, he said its not getting fire so i guess its either the coil or the ICM! I guess I ll know more tomorrow
To PLZ help!
