Plug for ?
Old Jul 7, 2009 | 07:23 PM
wnafly's Avatar
wnafly
Default Plug for ?
Does anyone know where this plug goes?, its on the passenger side, next to the air filter on the bottom right side. Has a green and black wire, i checked lights and signals, they work fine. i changed my air filter and noticed it laying there. it's a 96 vette.
Old Jul 7, 2009 | 08:25 PM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
Under-hood light maby??
Old Jul 7, 2009 | 08:43 PM
The Green Hornet
Just checked my 91, the only other green & black ti might be are the horn or the headlight motor.
Old Jul 7, 2009 | 08:50 PM
wnafly's Avatar
wnafly
horn and lights are all pluged in and work fine???,,got me scratching though. yes, both hood lights are working too.
Old Jul 7, 2009 | 09:41 PM
bizaro's Avatar
bizaro
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
both underhood lights are on? picture?
Old Jul 9, 2009 | 04:54 PM
wnafly's Avatar
wnafly
Anyone else have any idea what it's for?
Old Jul 9, 2009 | 05:33 PM
Goldcylon's Avatar
Goldcylon
Does the outside temperature display on the AC controls? The Plug could belong to the outside temperature sensor which is located on the underside of the car passenger side in front of the radiator. Or maybe one of the cooling fans. Turn the AC on if both fans comes on then my guess would be the outside air temperature sensor. GC
Old Jul 9, 2009 | 07:10 PM
wnafly's Avatar
wnafly
I don't have an outside temp guage, hmm i wonder if thats why it's just there, i'll have to check my fan plugs anyway just in case,,Thanks alot
Old Jul 9, 2009 | 08:14 PM
Goldcylon's Avatar
Goldcylon
All 90-96 C4s with the electronic controlled AC should display an outside temperature temperature in the LED display of the AC controls. Normally the AC when turned on and the desired temp is set the AC will display a temp and the word "outside" next to it. Its tucked up in there before the radiator on the passenger side. The early C4s use the same sensor so im thinking they just display another way
Heres what you looking for Bro.
http://www.zip-corvette.com/Zip/prod...BA17D03017B5B5
Old Jul 9, 2009 | 08:32 PM
wnafly's Avatar
wnafly
unfortunately, i don't have the electronic controlled ac with LED readout option. but it's a great thought, thanks Goldcylon
Old Jul 9, 2009 | 08:48 PM
STL94LT1's Avatar
STL94LT1
It's for the outside air temp sensor, not the fans.
To Plug for ?
