Removal of minor scratches
Old 07-10-2009, 12:00 PM
daca
daca's Avatar
Default Removal of minor scratches
The other day I uncovered my polo green 94 vert and I noticed that there were minor scratches on the above my right rear lights. They appear to have been done by a critter. They are not deep and I was wondering if there is any way to remove them with a wax compound or something similar. Appreciate any help.
Bob
Old 07-10-2009, 12:23 PM
Quinny
Quinny's Avatar
If the scratches are right through the paint, there isn't alot you can do other than get some touch-up paint.
If not, try polishing it out yourself - you can get coloured polishes that make it a little easier. If that doesn't work, get a paint shop (or do it yourself if you have an electric buffer) to do a proper 'cut & buff' job using a cutting compound and electric buffer.
Old 07-10-2009, 01:34 PM
Heckler45
Heckler45's Avatar
If they are not down to the paint you can try using a cleaner wax (I find Meguiers or 3M make a good one) or a 3 step cleaner/wax system like those offered by Mothers or Meguiers.
If those don't work you can try something more abrasive such as a rubbing compound followed by a polishing compound, and maybe then a cleaner wax. If your not sure how to use the compounds I would seek out expert advice before trying this yourself as they can be tricky to use (you could make it worse if you don't use this stuff correctly).
-Dave
Old 07-10-2009, 01:41 PM
Z51JEFF
Z51JEFF's Avatar
There are some scratch removers or you can use car wax and a buffer.The buffer you want to use is one of the idiot proof buffers you find at Sears,not what the pros use.If you not familiar with waxing a car what you want to do is stay away from edges and corners.Do not use rubbing compound.
Old 07-10-2009, 01:51 PM
pianoguy
pianoguy's Avatar
The Porter-Cable 7424 buffer is pretty idiot-proof (I should know, being an idiot).
Old 07-10-2009, 02:00 PM
mcnulty95
mcnulty95's Avatar
I use Blue Correl Scratch Remover. You can get it at any auto place. Easy to use and works well.
Old 07-10-2009, 02:38 PM
uptown193
uptown193's Avatar
Take a pic of it, a visual for us is usually good for reference.
Old 07-10-2009, 02:58 PM
jimmymack
Support Corvetteforum!
jimmymack's Avatar
St. Jude Donor '09-'10-'11,'13-'14-'15-'16-'17-'18-'19-'20-'21,'22-'23-'24
We idiots have to stick together
Old 07-10-2009, 04:41 PM
RLG
RLG's Avatar
All Kidding aside If you have never used a Buffer , Don't start on your Vette.
I use a De Walt variable speed.
The factory didn't put a lot of paint on these cars so you can burn through real easy then your really screwed.
There are several companies that make a scratch remover that is hand applied, try that first.
To Removal of minor scratches
Quick Reply: Removal of minor scratches
