A/C problem
Old Jul 18, 2009 | 06:44 PM
T-800's Avatar
T-800
Default A/C problem
i turned on my a/c today and the air comes out of upper vent and lower vents but on the pictured vents no air comes out , nothing at all what can this be due to??
Old Jul 18, 2009 | 07:16 PM
T-800's Avatar
T-800
bump
Old Jul 18, 2009 | 07:19 PM
pianoguy's Avatar
pianoguy
There's a plastic vacuum check valve on the passenger side of the engine under the fuel rail cover - have a look at that first. If that's the culprit, your cruise control probably isn't working, either, but you should be able to get a new one for $5 or less at any auto parts store.
If you have a '96, a common problem is that the soft rubber nipples on the HVAC programmer can collapse. Here's a thread about it:
http://forums.corvetteforum.com/c4-t...l-problem.html
Old Jul 18, 2009 | 07:24 PM
T-800's Avatar
T-800
thanks alot ill check it out
Old Jul 18, 2009 | 07:26 PM
pianoguy's Avatar
pianoguy
Good luck!
BTW, this is the check valve you're looking for:
Old Jul 18, 2009 | 07:34 PM
T-800's Avatar
T-800
Good luck!
EXACTLY what was wrong with it! thanks alot man i really appreciate it problem fixed
Old Jul 18, 2009 | 08:23 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Old Jul 18, 2009 | 08:43 PM
pianoguy's Avatar
pianoguy
Excellent!
To A/C problem
