96 Lt1 Squeaks
Old Jul 19, 2009 | 02:54 PM
papafrancisco's Avatar
papafrancisco
Default 96 Lt1 Squeaks
Searched for squeaks and everyone says this is normal However mine never squeaked until recently. Noticed going over a wide speed bump that passebger side squeaks. Is it possible for shocks to squeak? Shocks appear original since they appear to have Bilstein and GM name on them. Besides been wanting a reason to replace...
Old Jul 19, 2009 | 11:39 PM
mrmtrtrnd's Avatar
mrmtrtrnd
My 93 started squeaking so I put it up in the air and pulled the wheels off and lubricated everything that had a chance of squeaking and some that probably didn't. It doesn't squeak anymore but of course I still have the rattles.
Old Jul 19, 2009 | 11:42 PM
jimg's'93's Avatar
jimg's'93
It could be your mono-spring pad rubbing on the right side at the pad.
Old Jul 20, 2009 | 10:31 AM
dreamer2468's Avatar
dreamer2468
St. Jude Donor '09-'10-'11
Thats what I was thinking, I dont hear squeaks hardly ever, but rattles, now thats an entirely different story.
I did have one rattle that I found the cause of though, it was the bushings in the front, there was play in there, resecured it, and its been greatly reduced.
I dont think all of them will ever go away though. I will just always hate driving over rougher roads.
Laura
Old Jul 20, 2009 | 11:11 AM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
If your squeak is coming from the rear, try spraying lubricant (WD40) on your rear control arm bushings. Worked for me, at least until I replace them.
Old Jul 20, 2009 | 11:17 AM
DougSilver's Avatar
DougSilver
The worst squeaks/creeks that I get are when the underhood temperatures get high enough to trigger the second fan turning on. Going over the slightest bump or undulation in the road results in noisy creaking from the front. If I pop the hood and push up and down on the frame, it sounds like it is coming from the very front of the car. My mechanic says it is probably bushings. The creaking is annoying but I have been living with it--never happens when the temps are lower.
Doug
Old Jul 20, 2009 | 02:59 PM
Eakster's Avatar
Eakster
Spray some silicon lubricant on all your bushings
control arms need grease lubricant - they have nipples :o
To 96 Lt1 Squeaks
