Does anyone know where you can buy epoxy primer in a rattle can locally.I have a area on my hood to spot in about the size of a soccer ball(bare smc)The local auto paint supply dosen't sell it in rattle cans and they want $100.00 a quart for the stuffI only need about enough to fill up a pill cup(lancaster pa area)THANX
Most epoxy primer's are 2 part. I'm not sure if you can get it in a spray can.
The last time I was at the paint store there was a 2 part epoxy primer in an aerosol can,bizarre looking setup.The can had an exposed section that allowed the activator into the can but its a one use deal.
Well I came up with a easier solution .I groung out the repair area a little deeper then filled it with smc filler,sanded and then primed with 4 coats of high build primer(problem solved)
