Just noticed a small puddle of light orange liquid on the garage floor.
It would be under the area of the engine not the radiator.
Any thoughts on what this means.
The water pump has a small "weep hole" located under the area where the shaft from the pulley enters the pump.
You'll have to get a small make-up mirror to fit under there to inspect.
The weep hole is designed to warn you prior to your water pump failing.
This week it is the small puddle....maybe small for three weeks and it could be inconsistent.
Then one day the river will be under there.......That is the day you need to park it until the pump gets swapped.
Your '86 is not like the '84...the '84 had everything attached to the four studs that holds the water pump in place. The '86 has a lot of things there...but not as bad as the '84....it took me 2 days to swap mine.
Don't make the mistake of ignoring the timing chain cover while you are there.
Orange or red? Look inyour coolant reservoir and see what color your coolant is. If it's not orange (Dex) then you've got either steering or trans fluid leaking.
You won't know until you truly determine just what is leaking. If it's tranny, it could be as simple as the pan or coolant lines.
I'd raise the car and look around closely. Wipe all traces of fluids anywhere and then revisit the engine later; preferrably after running her and cycling the gears and steering (NOT while up on jacks!). Note where you're seeing the puddle(s) in relationship to the engine/drivetrain.
Get a 5 X 7 card and put a drop of coolant, p/s fluid, oil, tranny fluid and you'll know what it is...OR get under the car and find out.
