89 Stero System
Old Jul 24, 2009 | 12:17 AM
jbabs15's Avatar
jbabs15
Default 89 Stero System
Has any one had a problem with there bose system? For some reason this spring when we took it out and tryed using the radio a loud high pitched noise came on and almost sounded like a alarm was going off. In the pannel is says anti lock. Never said that before. Any suggestions? How much is it to get a new bose to replace them becasue i know that 2 of them always were going bad and had a cracking noise but never this loud alarm noise.
Old Jul 24, 2009 | 06:57 PM
RLG's Avatar
RLG
Almost everyone has a problem with the Bose system.I took it out.
Old Jul 24, 2009 | 07:40 PM
torchred89's Avatar
torchred89
Tell somebody that hasn't
Old Jul 24, 2009 | 10:07 PM
Scott-89's Avatar
Scott-89
Same here. I took it out and replaced everything with aftermarket stuff. All 4 speakers would only work about half the time. I would get a squeal out of the left rear sometimes.
Old Jul 24, 2009 | 10:11 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default Bose
This is an easy fix. Anything that says "bose" on it goes straight to the trash can. Get a new sound system. You will love it. Will make driving your vette so much more enjoyable. JMO.................
Good Luck,
Corvette Mike
Old Jul 24, 2009 | 11:56 PM
jbabs15's Avatar
jbabs15
Were they just that bad that year?
Old Jul 25, 2009 | 12:19 AM
RLG's Avatar
RLG
they were bad for all years, I have a 90
Old Jul 25, 2009 | 12:23 AM
jbabs15's Avatar
jbabs15
In that case whats a good stero system that has good quality.
Old Jul 25, 2009 | 09:12 AM
RLG's Avatar
RLG
I used a Kenwood from stereo on line, you will need the install kit and an antenna extension. There are a couple of other mods I had to do , but I don't know if there is a difference between the years.
Old Jul 25, 2009 | 09:13 AM
RLG's Avatar
RLG
you might need the radio relay bypass wiring harness.
To 89 Stero System
