Keyless Entry
Old Jul 27, 2009 | 10:14 AM
tc sr's Avatar
tc sr
Default Keyless Entry
Why does the keyless entry lock the doors with the keys in the ignition? I know if you hold the keyless entry button down you can stop it. But it should not lock the car with the keys in the ignition.
Old Jul 27, 2009 | 12:25 PM
Goldcylon's Avatar
Goldcylon
For safety
Old Jul 27, 2009 | 02:09 PM
markKlein's Avatar
markKlein
Something is malfunctioning. It is not designed to lock the doors when the key is in the ignition. (But to be safe, never leave the fob in the car).
Old Jul 27, 2009 | 02:36 PM
Wathen1955's Avatar
Wathen1955
My 96 will not do that. It will keep clicking (opening the doors until I insert the key in the ignition).
So when I walk up to the car, it will open the doors. When I walk away, it will lock the doors.
Old Jul 27, 2009 | 02:55 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I've purposely locked the door with the key in the ignition and the door always unlocks itself after closing the door. (did this as a test of course)
Old Jul 27, 2009 | 04:27 PM
jhammons01's Avatar
jhammons01
Not quite accurate
The VKE 1000 has a loop that needed to be cut in order to disengage this feature.
If you find your PKE Head unit stuffed away in your car somewhere.....There is a door under the CCC symbol. Open this door and there are three "loop" toggles.
Red loop= Chirp On/Off. makes your horn chirp when the doors lokc.
Yellow Loop= Ignition Locks On/Off...this is the one you want to disable that pesky auto lock.
Blue Loop= Door lock pulse duration. .8 seconds at default.
Old Jul 29, 2009 | 11:56 PM
jhammons01's Avatar
jhammons01
^^So just for kicks I dug mine out this eve.
The little door was there....but there was no way to reach those wire loops with anything that would cut them.
I wound up taking out the four screws that holds the housing together...this exposed the PCB and the three wire loops.
Clip the Yellow and remove a HUGE AGGRAVATION.......
I want the doors locked.......I'll reach over and push the button.....I don't need something to lock me in/out every time I turn the key on
Old Aug 4, 2009 | 08:12 AM
Lisa Wilson's Avatar
Lisa Wilson
6th Gear
I suppose for security point of view.
Keep Sharing.....
Old Aug 4, 2009 | 09:29 AM
Kinkajou's Avatar
Kinkajou
Old Aug 5, 2009 | 05:40 PM
CAJUN C4's Avatar
CAJUN C4
Where was it located ?
To Keyless Entry
