Spare tire question
Old Jul 27, 2009 | 07:11 PM
drrobstar's Avatar
drrobstar
Default Spare tire question
I pulled out the spare tire on my LT4 this weekend to clean it and the compartment. Needless to say, after 13 years, the compartment was nasty.
In replacing the spare, I couldn't tighten the compartment bolt all the way because the tire pressed up against the rear frame bar...is that the correct fitting? Seems like an odd design....and probably damages the tire if you tightened too much. I tried adjusting the tire compartment and bolt... What do you guys think?
Old Jul 27, 2009 | 11:02 PM
pologreen1's Avatar
pologreen1
take it out, and leave it out. might make the car more fun
Old Jul 28, 2009 | 06:17 PM
skirby's Avatar
skirby
The same thing happened to me. Take your rear tag off and you will see the position that the hanging bar needs to set into. It probably fell out of its holder.
Hope this helps.
Old Jul 28, 2009 | 07:07 PM
c4cruiser's Avatar
c4cruiser
Might not be a good idea. The spare tire is part of the rear collision energy absorption system. If you get hit from behind, the spare tire helps to transfer the energy from the point of impact down to the batwing. It also provides some crush resistance for the gas tank.
Old Jul 28, 2009 | 09:54 PM
Goldcylon's Avatar
Goldcylon
Correct if you take it out make sure you put the spare tire delete bar and brace in the voided space.
Old Jul 28, 2009 | 10:18 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
And what happens if you get rear ended?
Old Jul 29, 2009 | 12:41 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
squish
Old Jul 29, 2009 | 07:36 AM
Weav's Vet's Avatar
Weav's Vet
I agree.
The spare tire delete bracket would be nice but you can't find them. I think it's a crap shoot ridng in these cars anyway. A spare tire isn't going to make a whole lot of diffeence if rear ended hard enough to cave in the back of the car.
Old Jul 29, 2009 | 10:24 AM
mcnulty95's Avatar
mcnulty95
I didn't know the spare had anything to do with helping reduce impact?
Old Jul 29, 2009 | 10:42 AM
runner140*'s Avatar
runner140*
There are two levels/adjustments on the spare tire pan. One is for the small tire...the other is for a larger tire.
Old Jul 29, 2009 | 12:17 PM
drrobstar's Avatar
drrobstar
Thanks for the comments. I was under the car last night and made sure that the hanging bolt was in its holder. I didn't remove the license plate, but I just shined my flashlight up into the bolt opening. Everything looks fine and aligned, but I still don't understand why the tire doesn't fit between the rear axel and the rear frame rail. It seems crazy that the spare is properly fit pressed against the frame rail. So, are we sure this is the right placement? Maybe I should shoot a pic and post it. Do all of your spares press against the frame rail too?
Old Jul 29, 2009 | 02:18 PM
flynn508's Avatar
flynn508
correct
Old Jul 29, 2009 | 04:44 PM
Goldcylon's Avatar
Goldcylon
Originally Posted by flynn508
correct
for a standard 8.5 or 9.5 wheel the wheel will just hang lower in the rear tray than the doughnut wheel. Unless you have a ZR-1 and had a flat on one of the rears, then GM gave you a handy bag to put the rear wheel (17X11) into the back of the car and staps to hold it down.
Old Jul 29, 2009 | 10:08 PM
skirby's Avatar
skirby
Trust me. Take the rear tag off. There you will see the other position.
Try it, it worked for me.
Old Jul 29, 2009 | 11:17 PM
CE1's Avatar
CE1
When this happens you'll be glad that spare is there...
It does help alot in these cases... just our $.02
Old Jul 29, 2009 | 11:47 PM
pologreen1's Avatar
pologreen1
to all, many people take out the spare tire, and do not replace with the delete kit, reason being is they can't find one reasonable or they can't make one.
This has been an ongoing debate if the tire was really intended to take up any impact. I am not sure, but in my mind if I get rear ended in this thing, it is toast either way.
Old Jul 30, 2009 | 12:05 AM
CE1's Avatar
CE1
Good as new, exhaust is better........
To Spare tire question
Old Jul 30, 2009 | 12:17 AM
samsonb's Avatar
samsonb
I don't see a point in removing the spare tire.
Anyways, is there supposed to be black puddy type goo in the top of the spare tire screw hanger that is behind the license plate? When I cleaned my spare tire, I remove this puddy stuff as I figured the PO had it put in there when he had the car repainted. Then I was looking at a Vette for sale on a car lot, and the tag was removed, and noticed it's tire hanger thing had black puddy on the top like mine.
So, I figured it might of been that way from the factory? I hope it won't hurt anything not having it there.
Old Jul 30, 2009 | 12:10 PM
drrobstar's Avatar
drrobstar
Ok...I'll pull of the license plate tonight and take a look. Still though...I still think its the tire that's not fitting. The compartment pan is in the right position and it appears the screw bolt is too.
Thanks for the input everyone...I know this is a s--t detail, but I like things to be right.
Old Jul 30, 2009 | 03:17 PM
donnall's Avatar
donnall
Cruising
Default Spare tire
I'll be keeping my spare tire, it's saved me twice when I had flats a 100 miles from home.
Once about 10pm on a Sat night at the Memphis Airport underground parking garage, not a place you want to hang around even in the day time. And another Sat evening on the road.
Both times if I had not had a spare to limp home on I would have had to be towed to parking lot somewhere, checked into a motel, and waited until Monday to find a new tire. IF I could have got one then.
You could end up stranded for a few days waiting on a new tire to be shipped to you. So I'll be keeping my SPARE tire.
hth
Don
PS: I also carry a couple can of Fix-a-flat and a little compressor.
Along with Good Sam Road Side assistance.
