Brain teaser
Old Jul 28, 2009 | 04:08 PM
iamfine2's Avatar
iamfine2
Default Brain teaser
Ok gang, here you go:
I have the targa top off of my 1995.
When I pull into a driveway at a slight angle so as not to scrape the front spoiler on the driveway lip, as i hit the lip my automatic door locks un lock!
Ready.......set..........GO!
Old Jul 28, 2009 | 04:17 PM
Sweet 90's Avatar
Sweet 90
It was a rare option. Your Vette knows it's home and she is just unlocking the doors for you
Jim
Old Jul 28, 2009 | 04:54 PM
Atari's Avatar
Atari
Wow, I have a similar issue going on. Sometimes when I get in and close my door, both doors unlock as if I pressed the button to unlock them. It doesn't do it all the time though.
Old Jul 28, 2009 | 04:55 PM
Doug 87L98's Avatar
Doug 87L98
You pull in at such an angle that your key fob hits the side of the steering column. And that activates the door locks.
Am I right?
Old Jul 28, 2009 | 04:58 PM
Black84's Avatar
Black84
You have an invisible fence for your dog (or dogs) and it is the fence signal "tripping" the remote leyless function...
Old Jul 28, 2009 | 06:11 PM
GREENC493's Avatar
GREENC493
Do the interior lights come on as well. Sometimes if I get my 93 at just the right angle the dome lights trip because the car will flex enough to ground the sensor. Maybe this happens and unlocks the doors for you.
Old Jul 28, 2009 | 06:47 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Same problem here.
Old Jul 28, 2009 | 07:41 PM
RedVette84's Avatar
RedVette84
What's the distance from the equator to your house and what quarter was the moon in?
Old Jul 28, 2009 | 09:52 PM
Goldcylon's Avatar
Goldcylon
Whats the air velocity of a coconut ladden swallow????
Hmm I wonder if either the door ajar switch is is issue. Pull into your driveway at night time and see if the interior lights go on as stated.
Old Jul 29, 2009 | 01:51 AM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Jim
I thought that option was only available with the ejection seat package
Old Jul 29, 2009 | 03:31 AM
Avantos's Avatar
Avantos
Hi, VERY long time lurker, 1st time poster. Registered to answer this question. Had the same issue myself.
Check the Driver side door, there should be a type of plug sticking out of the door that when you push it in, will turn off the interior lights. You should be able to see a little round plastic do-hicky (technical term ) in the body. If you can shim it up, that might just take care of the issue. At least it worked for me. As I understand it, the body flexes enough to trip that thing, making the system think the door is being opened.
Hope this works for you!
Old Jul 29, 2009 | 10:01 AM
mrmtrtrnd's Avatar
mrmtrtrnd
[QUOTE=Avantos;1570952008]Hi, VERY long time lurker, 1st time poster. Registered to answer this question. Had the same issue myself.
Welcome and glad to have you as a member That's the very issue I'll be working on today. Sometimes while driving down the street in the evening it looks like a light show going on in my car . I figured one or more of the switches need adjusting or replacing. Now to get it traced down and fixed.
The door lock thing I just don't know. Something must be lose and making contact once in awhile and activating the system. My light situation only happens now and again.
Old Jul 29, 2009 | 10:07 AM
mcnulty95's Avatar
mcnulty95
Your car is possessed. You need an exorcist.
Old Jul 29, 2009 | 10:25 AM
Sweet 90's Avatar
Sweet 90
No that only came with the James Bond Corvette RPO 007
Jim
Old Jul 29, 2009 | 12:29 PM
iamfine2's Avatar
iamfine2
That one i like!
Old Jul 29, 2009 | 12:30 PM
iamfine2's Avatar
iamfine2
I don't havr the keyless entry!
Old Jul 29, 2009 | 01:01 PM
floridamale's Avatar
floridamale
Your injector seat is malfunctioning check the FSM for repair procedure
Old Jul 29, 2009 | 02:16 PM
flynn508's Avatar
flynn508
Jim
To Brain teaser
