clutch pedal adjustment?
95, 6 speed, can the pedal itself be adjusted?..I sometimes have trouble shifting into first gear, unless I double pump the clutch. no fluid leaks, replaced slave and master less then 3,000 miles ago. Today I bled the clutch slave and it is still the same. The clutch feels fine no slippage at all. I have to push the pedal clear to the floor to disengage, is the pedal itself adjustable? or am I looking at a new clutch soon?
It could be that there is wear on the pedal pivot point. This can happen, especially on a high mileage car. Try to see how far down the pedal goes down before things actually start moving. It might be easier if you have help doing this.
