91 Radio Dead
Old Aug 2, 2009 | 09:46 PM
TumblingDice's Avatar
TumblingDice
8th Gear
Default 91 Radio Dead
I have a Bose in my 91 coupe, which worked fine until recently. The radio will not turn on, the antenna will not go up, and nothing can be heard from any speaker. The face of the radio does light up and show the time (incorrectly) when the power button is pushed. Any ideas? Any help would be much appreciated.
Old Aug 2, 2009 | 09:52 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
is the fuse blown
Old Aug 2, 2009 | 09:54 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
diddo
Old Aug 2, 2009 | 10:24 PM
TumblingDice
8th Gear
is the fuse blown
Which fuses control the radio? Also, I forgot to mention that occassionally (once or twice since the radio quit), the radio would come on, antenna and all for maybe 30 seconds or less. Then it shut back off, antenna back down.
Old Aug 2, 2009 | 10:29 PM
jimg's'93's Avatar
jimg's'93
That almost sounds like a bad ground. A fuse either works or not. Unless you have corrosion.
Old Aug 2, 2009 | 10:30 PM
TumblingDice
8th Gear
That's what I was thinking about the fuse either being bad or not.
Old Aug 3, 2009 | 10:33 AM
TumblingDice
8th Gear
OK, replaced the radio fuse and ctsy fuse, both worked fine, not the problem.
Old Aug 3, 2009 | 11:13 AM
Sweet 90's Avatar
Sweet 90
Have you unhooked the battery latley?. Radio may be locked.
Jim
Old Aug 3, 2009 | 11:58 AM
TumblingDice
8th Gear
We replaced the alternator recently, so yeah the battery's been unhooked. But if it was locked, would it come on randomly?
Old Aug 3, 2009 | 12:06 PM
Sweet 90's Avatar
Sweet 90
No probably not. Maybe time for an aftermarket radio.
Jim
Old Aug 3, 2009 | 12:53 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Sounds like the CDM/tuner module's gone ****-up. It's the central processor for these damned things. For your year, it's located under the dash on the passenger side (hush panel) and is a PITA to access. You darn near have to be a midget contortionist to get to it.
I'm thinking about seriously yanking all the Blose crap, by-passing it with one of those wiring harness thingies and getting a decent JVC radio/CD/cassette player with aftermarket speakers.
Old Aug 3, 2009 | 08:16 PM
TumblingDice
8th Gear
Well, I think I have to agree. I'm going to replace it with a Pioneer. Thanks for all the input.
Old Aug 4, 2009 | 07:46 AM
onedef92's Avatar
onedef92
I think I'm goin' with the JVC KW-XC410 CD/cassette player.
Old Aug 4, 2009 | 10:04 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
You gentlemen need to go to the Audio section of the forum and read the C4 sticky at the top of the section. Lots of good info there. Also, the is a forum on car audio that would be worth looking at. http://www.diymobileaudio.com/forum/
If you have any questions, feel free to ask, I have had my system in and out several times.
BTW, no need to buy a harness from anyone. The C4 FAQ will show you how to hook up your new head unit.
Randy
Old Aug 5, 2009 | 08:49 AM
frenchyoliver's Avatar
frenchyoliver
I rewired all for a sony. No more heahache.....
Old Aug 5, 2009 | 07:15 PM
RLG's Avatar
RLG
I replaced the Bose stuff in my 90. I did by the $12.00 harness so I would not have to cut any wires on the original harness.
I don't know about 91 , but on the 90 you will need to add the resistors so the SES light will not come on.
I did replace and rewire all speakers.
Old Aug 5, 2009 | 07:54 PM
BILL-L's Avatar
BILL-L
Default Bose radio help
You also may want to try looking on this site. www.carstereohelp.com there is a lot of info. Factory car stereo repair inc. they are bose specialists.
To 91 Radio Dead
Old Aug 6, 2009 | 08:35 AM
onedef92's Avatar
onedef92
That's the route I intend to go, too. I'm sick and tired of nickle-and- diming myself away with the Bose crap. Does the wire harness by-pass the Delco CDM/tuner module and allow the power antenna to energize?
Old Aug 6, 2009 | 06:46 PM
J&D Corvette's Avatar
0J&D Corvette
Former Vendor
We have the cd cassette radio units rebuilt original for $359.00 exchange. Thanks
http://www.jdcorvette.com
Old Aug 6, 2009 | 06:58 PM
RLG's Avatar
RLG
Yes the antenna works fine. in fact you can leave the rec. box in place , just unplug it and plug the harness in.
