lets talk alternators
Old Aug 6, 2009 | 07:08 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default lets talk alternators
1. Am I the only one out there repairing his own alternators?
2. What are the common causes for alternator failure that you are seeing?
3. Do you have problems getting quality parts?
4. Is heat a factor in your alternator usage?
Old Aug 6, 2009 | 07:17 PM
Z51JEFF's Avatar
Z51JEFF
I rebuild my own.Most of the time its the reg that dies.
Old Aug 6, 2009 | 07:24 PM
basselope's Avatar
basselope
Quite possibly. The last time I wanted to rebuild an Alt the diode trio was $35.00 and a reman unit was $40.00. Shortly after that Holley carb kits went from $15.00 to $40.00 or more for the same cardboard. (now where did I put that soapbox?)
Age, Grunge, Heat and crappy components.... in that order.
...or any parts at all for a reasonable price!
Usage?...no.
A decent Alt should easily be able to handle the heat under the hood... at least when compared to all of the other items under there that can get heat-soaked and break down over time. Under normal usage, I would suspect that grunge accelerating wear on the commutator coupled with the added stress placed on the electronics that comes with age to be the main culprits. That and crappy components.
Old Aug 6, 2009 | 07:37 PM
coupeguy2001
my alternator gets so hot, that the diodes break and fail, the solder melts on the connections, and the diode boards are no good.
The plastic insulator on the battery connection gets soft with that much heat, and the nut tension relaxes, and the voltage regulator terminal gets so hot, the plastic housing melts on the voltage regulator.
Of course it's 114 outside, and the car outside temp indicator reads 119 degrees.
The slip rings are always smooth and brush holders are the throwaway parts that never need replacing cause the high current end of the alternator burns up before those two can wear.
There is no grunge in the alternator, they don't last long enough to accumulate any, dust maybe............
I am repairing an alternator every summer. I have 3 incase I eat 2 in a summer.
Old Aug 7, 2009 | 12:08 AM
Klondike's Avatar
Klondike
Interesting! That's something I never considered before. But the cars I was driving weren't special either, so parts were cheap. There is a super good electric motor & alt. re-builder here and he'll get my business if the Vette ever needs special component care.
Old Aug 7, 2009 | 12:19 AM
coupeguy2001
It's easy to do your own.
A rebuilt CIS alternator is $125 with a 2 year warranty at autozone, but the rebuild kit is $45.
Comes with bearings, brushes, diode board, silicone heat transfer paste, and 5 pages of instructions.
I bought the rear alternator housing from Sumit Racing with the cooling fins on the back.
Hoping this will help dissipate the heat.
Starters are easy to do as well.
Old Aug 7, 2009 | 10:45 AM
Flame Red's Avatar
Flame Red
I used to replace alternators almost as often as I filled up my tank! Ok, almost. Ten years ago I bought a Alternator from PowerMaster and have NEVER had to replace since!
To lets talk alternators
