I have a 1990, and the AC will not work, I have checked the fuses, the freon, the low pres cut off switch. at the LPCS I do not have 12VDC, if you put 12V to the connector the comp will run and blow cold air. So
where does the 12V come from? ,and why do you think I don't have it.
Thanks for your help
