starting issues
Old Aug 7, 2009 | 09:49 PM
jims1990vette's Avatar
jims1990vette
Default starting issues
My car will start every day but if it sets for a few days all it does is crank over. I replaced my fuel filter last week and the old one was clogged. It will start if I spray starter fluid in it I was told that the fuel pump has enough pressure. What is causing the fuel not to get to the engine after it sits? Hope someone knows
Old Aug 8, 2009 | 12:16 AM
jfb's Avatar
jfb
If it will start with starting fluid, you clearly are not getting enough fuel. When starting, the mixture is made rich to aid starting. That isn't happening and I would suspect the ECM losing that feature after sitting. A record of the start procedure via a scanner between when it will start and when it won't start might tell you where the problem is.
Old Aug 8, 2009 | 08:18 AM
jims1990vette
Thank you for that information, I will be telling my mechanic this morning.
To starting issues
