ASR lights?
Old Aug 7, 2009 | 11:05 PM
bangand0lufsen's Avatar
bangand0lufsen
Default ASR lights?
So i have been trying to figure out why my asr on and off lights do not work. i have checked and the on off button does work in turning it on and off but no lights. Nothing to big but i would like the lights to work on the dash cant always remember if i turned it off or not when i start out. Any ideas im thinking it just might be the bulb not sure, if it is the bulb is it very hard to get to it. Any suggestions would be great.
Old Aug 7, 2009 | 11:30 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
If you know the system is working as it should, I wouldn't worry about it. Probably just a burned out bulb.
ASR will always be on whenever you start the car. Even if you had it off when you shut the car off last.
Also, there are two different lights to look for. One as you would guess letting you know that ASR is turned off (ASR Off).
But if the system is turned on (default setting) another light will light up if ASR actually engages (ASR Active),
and you will feel the gas pedal pushing back up at you to stop the wheels from spinning.
