Temperature operating range
Old Aug 9, 2009 | 04:52 PM
95VetteMan1's Avatar
95VetteMan1
Default Temperature operating range
I was driving the other day and the temperature outside was 100 degrees.I noticed my digital temperature gauge went up to about 251 degrees is this a normal operating range?
Old Aug 9, 2009 | 05:28 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
No, that is not normal at all.
Sitting at a stop light for any length of time, 225-235 should be about as high as it gets.
Moving at any speed above 45mph, and you should never get over 200.
You need to make sure you don't have any airflow restrictions first. Radiator fins clogged up with leaves, bugs, feathers, etc.
Once you know you have proper airflow, then take a look at coolant flow. Old radiators do get clogged on the inside also.
Once they do, they won't cool like they should.
Old Aug 9, 2009 | 05:33 PM
VinceC4's Avatar
VinceC4
WOW!!! way to hot, highway should be around 200-205..stopped in traffic 215-225..check the entire system for dirt, bad t-stat, bad hoses, bad rad
Old Aug 9, 2009 | 09:11 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Unless you were going uphill, 251 it's time to run the heater and stop.
To Temperature operating range
