Road walk?
Old Aug 13, 2009 | 04:57 AM
Crazy5.7's Avatar
Crazy5.7
Default Road walk?
Is it normal for C4's to experience road walk at high speeds? It's pretty bad when you're on a small highway even cruising at 70. Makes me a little nervous sometimes with some of the cruddy shoulders we have around here.
Old Aug 13, 2009 | 08:36 AM
RedVette84's Avatar
RedVette84
That really isn't normal unless the road is really grooved and the wide tires try to track in them. I'd have the front gone over and realigned. Check your tires if they are worn also.
Old Aug 13, 2009 | 09:10 AM
ddahlgren's Avatar
ddahlgren
Mine did that driving it home from Philly to CT the NJ turnpike the worst in places. I changed the tires to some Kuhmos Exsta all season ultra HP had the alignment changed to 6 deg caster -0.5 camber all around 1/32 toe in front and 1/8 toe in rear and drives like a different car.
Old Aug 13, 2009 | 09:47 AM
Sweet 90's Avatar
Sweet 90
Mine stays true at any speed.
Jim
Old Aug 13, 2009 | 09:56 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
With good tires and all suspension components in good shape, no it's not normal.
But like any old car (you didn't list what year or how many miles you had), parts wear out.
Some of this happens slowly over time and you really don't notice it that much.
My '96 is stable and behaves very well at any speed I've even driven it.
Tommy T-Bone's Avatar
Tommy T-Bone
St. Jude Donor '06-'07-'10-'11-'12-'13-'14
You can always have the front end inspected by a trustworthy source but I'm leaning toward tire selection.
Old Aug 13, 2009 | 10:08 AM
AstroMan1's Avatar
AstroMan1
Mine was like that and I got the steering rack replaced. Works much better.
Old Aug 13, 2009 | 11:08 AM
kimmer's Avatar
kimmer
C4 of the Year Finalist
worn tie rod ends will do it every time
Old Aug 13, 2009 | 11:11 AM
aquablue96's Avatar
aquablue96
Yes tires! We also found that the run flats do it horribly. We replaced the run flats on our c5 with regular tires and drives like a charm now. My 96 also has no trouble with walking!
Old Aug 13, 2009 | 11:13 AM
jhammons01's Avatar
jhammons01
36psi cures mine....since the Right Front has a slow leak I can tell you when it is at 34psi or 32psi.....air it up and all is well again.
Old Aug 13, 2009 | 05:30 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Mine will only do that at speeds over 175mph. Just kidding
Old Aug 13, 2009 | 07:48 PM
wnafly's Avatar
wnafly
175!! mine went 175 and a half it did really!! Course i had to wake up and go to work.
Old Aug 13, 2009 | 10:50 PM
Crazy5.7's Avatar
Crazy5.7
^^That happens! Haha.
Thanks everyone! You've been really helpful. I think I just need to check the air pressure in the tires for starters. Please forgive me for not posting anything about my car. It's an '89 with 153,000+ miles. I know I still need to have it checked out, but I really believe the cruddy road I was driving on had a lot more to do with it than I thought. Drove about a 60 mile round trip just a little while ago, and she drove smooth the whole time.
To Road walk?
