Headlights drop down while driving
Old Aug 13, 2009 | 11:20 AM
bobandgail's Avatar
bobandgail
4th Gear
Default Headlights drop down while driving
I have a 1988 Corvette convertible which I normally drive only during the days. But, the other day I was driving at dusk, so I turned the lights on and they started to stick while popping up, but on the second attempt they went up, but after a short while, one started back down. I couldn't get them both to stay up for more than a 10-15 seconds. The last time I drove it at night (about 2 years ago), they worked fine.
Is this something I need to take to dealership to fix or is there a simple adjustment that I can make to correct?
Old Aug 13, 2009 | 12:02 PM
aminnich's Avatar
aminnich
Read the sticky at the top of the tech section.
Old Aug 13, 2009 | 01:22 PM
jimg's'93's Avatar
jimg's'93
Old Aug 13, 2009 | 01:54 PM
gabezC4's Avatar
gabezC4
Default Bushings/Gears
Bushings/gears in the motor are worn out and aren't allowing the healights to rotate. The gears are probably stripped or the bushings are broken. Cheap fix at a place that knows what they are doing.
bobandgail's Avatar
bobandgail
4th Gear
I'm sorry, but being new to the forum I don't know what is meant by "read the sticky". Could you please clarify? Is there an icon called sticky?
Old Aug 13, 2009 | 01:58 PM
bobandgail's Avatar
bobandgail
4th Gear
Thanks for your reply. Is the picture above your reply a picture of the gear in question?
Old Aug 13, 2009 | 02:22 PM
bobandgail's Avatar
bobandgail
4th Gear
I found the tech section and the appropriate "Sticky". Thanks a lot. But the pictures don't display on the messages. How do I see the pictures? Is that a set up option when I log into the forum.
Old Aug 13, 2009 | 03:15 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Perhaps this link will *ahem* bring things into focus...
http://www.corvettefever.com/howto/33098/index.html
Old Aug 13, 2009 | 05:08 PM
jimg's'93's Avatar
jimg's'93
Yes. You can buy them in plastic or bronze (in the pic). Pretty cheap and easy. Just be cautious of the (#4?) screws holding the motor cover on. They break pretty easily....ask me how I know this
To Headlights drop down while driving
