insrument cluster problems
Old Aug 14, 2009 | 12:20 PM
dferrell07's Avatar
dferrell07
2nd Gear
Default insrument cluster problems
i have purchasad a 1987 it runs great but i am having a problem with the instrument panel, the lcd lights up but it shows no information. can someone tell me what may be wrong and how to fix it?
Old Aug 14, 2009 | 12:23 PM
jfb's Avatar
jfb
The LCD panes can be replaced, but there are also some integrated circuits on the rear circuit board and a switching power supply that drives the segments. The panes are $50 to $100 each depending on where you get them and that is an expensive experiment. I would recommend you send your cluster to a repair place.
Old Aug 14, 2009 | 12:28 PM
dferrell07's Avatar
dferrell07
2nd Gear
could there be a wire that feeds information to the unit that is not getting good connection or will i have to replace the entire thing
To insrument cluster problems
