Climate Control Question
Old Aug 19, 2009 | 06:21 PM
Hondo48's Avatar
Hondo48
Default Climate Control Question
(91 Coupe)Searching for info on air conditioning problem, i see recommendations to clean the ECM. My Climate control has to be re set allot (Pull 2 fuses). It does not want to stay on with the "Auto" fan mode on. I checked to see if i had any codes and none come up. Several threads suggest cleaning the ECM. Where is it? Do I need to pull the climate control itself?
Old Aug 19, 2009 | 06:36 PM
jimg's'93's Avatar
jimg's'93
On your '91, the ECM is in the engine bay driver's side against the firewall directly over the battery.
Old Aug 19, 2009 | 06:40 PM
Hondo48's Avatar
Hondo48
Thanks! Is there a link with instructions on how to clean it? several i found in the achives did not work.
Old Aug 19, 2009 | 07:02 PM
jimg's'93's Avatar
jimg's'93
The only way I've ever cleaned mine was to clean the connectors with Dioxit (Radio Shack) or any spray contact cleaner.
Old Aug 20, 2009 | 10:19 AM
vetteman42's Avatar
vetteman42
Active Streak: 90 Days
YES you need to pull the Climate Control and clean the contacts. There have been several posts on this subject and specifically how to remove the unit and steps for cleaning the contacts.
I may have printed out a copy of the procedure...will look later today and advise via this thread.
I've used the procedure on my '91 coupe and it works!
SAVE THE WAVE
Old Aug 21, 2009 | 08:56 AM
vetteman42's Avatar
vetteman42
SAVE THE WAVE
I found my print out of the procedure to clean to contacts on the Climate Control Unit. It includes removal of the Unit as well as cleaning process. HONDO Please PM me if you would like a copy.
SAVE THE WAVE
Old Aug 21, 2009 | 09:14 AM
Hondo48's Avatar
Hondo48
Many thanks, guys! PM sent.
Old Aug 21, 2009 | 10:27 AM
vetteman42's Avatar
vetteman42
Instructions sent to your email address.
Good Luck!
SAVE THE WAVE
To Climate Control Question
