90 vent problems
Old Aug 20, 2009 | 04:11 PM
Youngin in a 90's Avatar
Youngin in a 90
Navigator
Default 90 vent problems
everytime i turn on the heat or ac, it will only come out at defrost and floor. i read the other posts and it seems like i have a thousand wires down by my accelerator pedal. i was hoping someone might have a picture of what i need to find exactly. thanks guys
Old Aug 20, 2009 | 04:23 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
on my dads old 91 vert. he had the same problem. and all it was some of the vacuum lines around the top of the engine were melted shut. and not allowing enough vacuum to operate the HAVC
Old Aug 20, 2009 | 04:39 PM
Youngin in a 90
Navigator
i looked but cant find anything wrong.
Old Aug 20, 2009 | 05:15 PM
Nowhere Man
I am talking about the small hard plastic lines that run under the runners.
Old Aug 20, 2009 | 07:24 PM
Youngin in a 90
Navigator
that wouldnt happen to have been connected to my egr valve now would it?
Old Aug 20, 2009 | 08:35 PM
Nowhere Man
i think some of them went there
Old Aug 20, 2009 | 09:25 PM
floridamale's Avatar
floridamale
The AC picks up its vacuum from the rear left side fitting on the plenum it runs into a T check valve, the AC connection is the bottom fitting the center one hooks into the cruise control. The check valve is located back by the distributor the AC line is a small hard plastic line that runs in the main loom along fire wall.
Old Aug 20, 2009 | 09:34 PM
Gary96's Avatar
Gary96
Try this link here, it has pics too. I had the same problem with my 96 and this fixed it.
http://forums.corvetteforum.com/c4-t...l-problem.html
Old Aug 20, 2009 | 09:43 PM
Youngin in a 90
Navigator
F*ck my life haha there are so many wires down by the pedal that idk what im looking at. i did see a tiny hose out by the firewall but i cant see where it goes or where it came from. i need to find a diagram of every vacuum hose there is in my car
Old Aug 20, 2009 | 09:58 PM
floridamale
This is the basic vacuum set up on a L98
Old Aug 20, 2009 | 10:14 PM
Youngin in a 90
Navigator
"TO HVAC" could be the problem. i had a prom made and i dont need my egr anymore and a mechanice took all the vacuum lines off of that and plugged a spot where a hose hooked up. im wondering if thats the HVAC hook up. a hose goes from the HVAC hookup on the intake in through the firewall and down by my pedal correct?
To 90 vent problems
