89 Quit
Old Aug 25, 2009 | 09:55 AM
eagleye's Avatar
eagleye
Default 89 Quit
Last night I went to start my 89 and it cranked and cranked and cranked but didn't fire. It has been running fine with no problems until last week when I had it out for a while. It ran just fine but when I was pulling into the driveway, it stalled and I had to crank it a few times to get it going again before I could pull it in the garage. I let it run a few minutes at idle and it seemed fine. I did replace the injectors back a few months ago and everything seemed fine. I have a limited knowledge of how to get codes etc. so any help would be appreciated.
Old Aug 25, 2009 | 06:56 PM
rodj's Avatar
rodj
http://www.neilkline.com/Tech%20Tips/obdcodes.htm
http://www.corvettebuyers.com/c4vettes/codes.htm
Old Aug 25, 2009 | 07:07 PM
Frizlefrak's Avatar
Frizlefrak
Let's start with the simple stuff....
Mount a fuel pressure gauge on the schrader valve on the fuel rail. Turn the key to the "on" position. The fuel pump should energize for two seconds and then shut off. How many pounds of fuel pressure do you get, and how long does it hold?
Answer that, and we'll go from there. Remember, troubleshoot, don't guess.
Old Aug 25, 2009 | 11:20 PM
eagleye's Avatar
eagleye
Thanks for the information. It might be a few days before I get to check this out. I will certainly post any results I get.
Old Aug 25, 2009 | 11:47 PM
jfb's Avatar
jfb
Engines need spark and spark at the right time, fuel and air and in the correct ratio and compression in order to start and run. Use your timing light to see if you have spark and spark at the right time. Use a fuel pressure gauge on the shrader valve on the end of the right fuel rail to see if you have 35-42 psi and see if it holds for a long time after the ign is turned off. Rapid fall indicates possible leaky fuel injectors. Use a noid light (available from parts stores) or make one with an LED (light emitting diode) and a series 680 ohm resistor, both available at Radio Shack, and connect across an unplugged injector socket and see if it pulses during cranking. If you use a homemade light, it must be connected with the correct polarity, try it both ways. Try starting fluid and if it starts, you have a fuel problem. If you have spark, correct timing, fuel pressure, injector pulses and no starting, measure compression.
Old Aug 26, 2009 | 08:23 PM
Frizlefrak's Avatar
Frizlefrak
There you have it.....a crash course in gasoline engines 101. That's all they need to run. Now you have to do 3 things.
1. Find out which is missing or deficient (troubleshoot)
2. Find out why.
3. Correct the deficiency.
Do those three things, all will be back to normal. Good luck.
Old Aug 26, 2009 | 10:42 PM
eagleye's Avatar
eagleye
Now I know what to do but finding the time to do it is the challenge. Thanks for all the input.
Old Aug 27, 2009 | 12:29 AM
Frizlefrak's Avatar
Frizlefrak
I hear ya. Sometimes there just doesn't seem to be enough hours in the day. Let us know how it works out.
Old Aug 27, 2009 | 01:49 AM
Calderone's Avatar
Calderone
my guessing bet from experience is coil
check if you have spark at the plug.-
a) electrical problem
b) fuel problem
c) both, but very difficult
Old Sep 16, 2009 | 11:10 PM
eagleye's Avatar
eagleye
I finally had some time to troubleshoot my problem. I used the service manual to go through some of the basics and passed a bunch of the tests. I'm trying to replace stuff that should be replaced under normal usage like the filter and the distributor cap. The distributor cap and rotor looked pretty beat so they got replaced. I did the spark thing and yes I have spark, I checked the resistance on each of the injectors and that passed. Each of the injector wires pulses when I crank the engine so that isn't it. I tried to find somebody who had a fuel pressure gauge but I finally broke down and bought one today. I don't have any pressure but the fuel pump runs. I still don't get any codes other than the 12. When I followed one of the charts in the service manual on Monday, I thought I had it when it said to replace the ECM. It seemed like I was going to fix this all by myself until the new ECM didn't do a thing. I'm trouble shooting the fuel aspect now and will keep trying. At least this hasn't been a real expensive adventure.
Old Sep 18, 2009 | 01:09 PM
pologreen1's Avatar
pologreen1
running yet?
Old Sep 18, 2009 | 02:29 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Crank, no-start condition? Check your coil and ignition control module (ICM) too. She may not be getting fire.
Old Sep 18, 2009 | 02:45 PM
Calderone's Avatar
Calderone
He has spark
Old Sep 20, 2009 | 11:06 PM
eagleye's Avatar
eagleye
The car is running! I feel pretty stupid about this but I should have checked the fuel pressure sooner as suggested by Frizlefrak early in this adventure. Not wanting to buy the test gauge I went in other directions. After finally buying the gauge I checked the pressure on Friday and it was zero. The pump ran when energized but something was still wrong so Saturday morning I removed the fuel pump assembly from the tank and took a look inside the tank to see nothing but EMPTY! My fuel gauge said I had a little over a half tank when in reality I ran out of gas in my own driveway. At least the stuff I replaced needed to be replaced with the exception of the ECM. SO the fix was actually $52.70 worth of premium gasoline. While the assembly was out of the tank, I couldn't get the readings for the float of 0 ohms when empty and 90 ohms when full. For now I am just going to keep track of the mileage when I fill up until I decide what to do next. Thanks for all the help with this.
Old Sep 20, 2009 | 11:26 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
Don't feel too bad, I have a working gauge and didn't notice how low it was reading until my 84 started to cough and miss.. Fortunately I was close enough to a gas station to fill up before it died..
Old Sep 20, 2009 | 11:33 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
This is so common of this crowd. Try the short cut first then learn the lessons the hard way!
WHen someone comes forward like "Frizzle", and pounds out a list of instructions with his post count we should believe he's got the experience to enlighten us. How frustrating it is to try and help.....
I'm glad you finally got it right. Attaboys to Frizzlefrak!
Old Sep 21, 2009 | 10:08 AM
eagleye's Avatar
eagleye
I didn't ignore what he suggested to do, the gauge said there was fuel in the tank so I went in a different direction with the service manual troubleshooting. I guess I need to pay more attention to the number of stars by a posters name to determine his or her credibility. Shame on me. I noticed another commonality of "this" crowd is the speed at which the criticism flies when posting results.
To 89 Quit
Old Sep 21, 2009 | 02:58 PM
Sweet 90's Avatar
Sweet 90
Oh please don't do that, because I would be considered a genius
Jim
Old Sep 21, 2009 | 03:52 PM
eagleye's Avatar
eagleye
I would have an assigned seat on the short bus with only 2 stars.
Old Sep 21, 2009 | 06:54 PM
JrRifleCoach
You said it....
The end result is that Frizzlefrak's tip was what resolved your problem.
