Another rookie shock replacement question.
Old Aug 25, 2009 | 11:14 AM
Corky740's Avatar
Corky740
Navigator
Default Another rookie shock replacement question.
I need a little help. I have 53K on my 93 Ruby with the original shocks and I think it is time to replace them. I know I can go get the stock replacements or ask the sixteen year old kid at the auto parts store what they recommend as a good alternative (not so much a fan of this idea). Or have one of you who have been down this road point me in the right direction. I do not have the selective ride control and I don’t think I need the coilover shock? But whatever I do end up installing I want it done right the first time, best bang for my buck. $300-350
Thanks.
Old Aug 25, 2009 | 11:29 AM
94z07fx3's Avatar
94z07fx3
If you have AC/Delco (or was it Delphi?) shocks replace with Bilstein. If you have Bilstein already then send them in for a rebuild.
Specifically what led you to conclude your shocks were needing replacement?
Old Aug 25, 2009 | 11:35 AM
jrp's Avatar
jrp
Thanks.
Get the Bilstein replacements for $270-$300 depending on where you look.
Why?
- OEM manufacturer with direct replacements. Hard to go wrong.
- You don't sound like you are going to need any performance characteristics beyond what was available stock. If you were, you would have mentioned it.
- They are in your budget, so you might as well avoid experimenting on cheaper parts which you may not like.
That's the reasoning I used, and it worked out great.
Old Aug 25, 2009 | 11:37 AM
jrp's Avatar
jrp
http://www.bilsteinus.com/cart/
Look up your part numbers here and then seek out a (supporting, of course) vendor.
Old Aug 25, 2009 | 01:24 PM
Corky740's Avatar
Corky740
Navigator
Am I missing something here 53K with original shocks? Is the mileage not an indicator for replacement? I would think that with reason, replacing the shocks would improve handling and stopping and overall ride. But this is my first corvette do the stock shocks last to 100K?
Old Aug 25, 2009 | 02:13 PM
94z07fx3's Avatar
94z07fx3
It depends on a few things. How is the car driven as well as which initial shocks were on the car. I would not change them if the only mark against them is 53K miles. It is perfectly normal for some oil and dirt to collect on the tubes of Bilsteins. Tire stores know this but use it against those who don't to sell them shocks they don't need. I think the only way to truly test a shock is on a shock dyno to see if it dampens within spec. But since I don't have a shock dyno and have no desire to own one I do this: http://www.basiccarrepair.com/testin...absorbers.html
Old Aug 25, 2009 | 10:40 PM
Corky740's Avatar
Corky740
Navigator
94z07fx3
I did test the rears and they are in good shape and the front shocks are pretty good for now. They are Bilsteins shocks so I can always send them in for a rebuild this winter or whenever.
I did not know that.
Thanks for your help.
Old Aug 25, 2009 | 10:52 PM
GKK's Avatar
GKK
My original Bilsteins have 95k on them and perform Great!
One of the Corvette Forum moderators had 136k on the stock Bilsteins and reported no problems and he drag races his Vette.
Old Aug 26, 2009 | 05:53 PM
MotorCity_87_C4's Avatar
MotorCity_87_C4
53k miles of WI roads and ya might need new shocks. I'm regretting putting Bilsteins on my 87 because the Michigan roads are littered with bomb craters and frost heaves.
Old Aug 26, 2009 | 07:04 PM
tblt44's Avatar
tblt44
Bilstein is the only thing I would put on.
Do you have Bilstein's now?
To Another rookie shock replacement question.
