help door panel?
Sep 1, 2009 | 09:13 PM
help door panel?
Wow what a design, this is what my right side door panel looks like:
Had the panel off thinking that I can get it lined back up better, i look at the panel there is nothing broke on the panel,
the plastic clips really suck! Were can I buy new ones?
Clips
This is the best I can get it:
it does not seem to stay hooked on top, Then it pop right out again: there something I’m doing wrong?
Sep 1, 2009 | 10:20 PM
Sep 1, 2009 | 10:36 PM
I asked the same question 2 days ago.. Im looking into fixing them with the metel brace trick as soon as I get time.
Sep 1, 2009 | 11:46 PM
Sep 2, 2009 | 12:03 AM
I had the same thing with my car.
I see the metal bracket trick looks pretty sound and should probably be the way to go.
I on the other hand used the zip tie method. It was SUPER easy and took about 5min to get the door 90% of the way back to normal.
Just drill holes in the top and bottom parts that are cracked. Insert zip tie and tighten it. Brings the two parts together nice and easy.
Sep 2, 2009 | 12:46 AM
Quote:
Originally Posted by
PUNISHER VETTE
That is a good idea! I believe I will try that, I may use alittle glue on them as well!
thanks for the idea
Sep 2, 2009 | 05:46 AM
Shaf1970
the door panel ribs are not broken they just don't seem to hook on the top
Sep 20, 2009 | 02:36 PM
94z07fx3
they are Panel to Rear Bumper? sure there right?
Sep 21, 2009 | 09:51 AM
RR40vette
They are probably stretched. The metal rib reinforcement worked great for my door problem.
Sep 21, 2009 | 11:54 AM
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
You can order the grommets online from Mid-America Motorworks (MAM).
Sep 21, 2009 | 11:56 AM
RR40vette
But, what do you do when there are
NO plastic ribs built in the door panel like on my 92?
Sep 21, 2009 | 12:49 PM
onedef92
I asked this several times in one of the other threads. I finally gave up and ran a long screw through the top. I hid it pretty good, but plan on new panels soon anyway
Sep 23, 2009 | 07:15 PM
94z07fx3
I bought a box of 100...only needed three. Anyone need any of these to help me recoup my cost?
Sep 26, 2009 | 06:26 AM
LannyL81
sent a pm,
Sep 26, 2009 | 06:29 AM
when i had the door panel off again, on the top it does not seem like it wants to hook in right like something is wrong. hmmmm
1993 ,
a10365 ,
back ,
clips ,
corvette ,
door ,
grommet ,
nylon ,
panel ,
panels ,
panle ,
screw ,
top ,
wwwclipsandfastenerscomseasearch
