Convertible question
Old Sep 2, 2009 | 04:33 PM
azrocketman's Avatar
azrocketman
Default Convertible question
I have an '86 convertible. There is a fabric "cover" that covers the top cover panel (package shelf area) with the top up. The cover flaps while driving with the windows down. Velcro or two sided tape will not work because it will be exposed with the top down. How did GM intend to keep this from flapping or "do they all do it"?
Always driving with the top down is not an option.
Steve
Old Sep 2, 2009 | 04:56 PM
rich653's Avatar
rich653
Same thing with my 86, don't really know what the cure is except closing the window..maybe someone else has an idea on this, I'd be interested too.
Old Sep 2, 2009 | 05:12 PM
yellow87's Avatar
yellow87
Not much you can do, I have tried several things, Velcro, pins, but as you said it moves when you take the top down. I did once try small airline type pillows shoved in the corners of the top, but you have to remember to remove them. I do use the same pillows to put between my vert window and top when taking it down so the fabric material doesn't sit on the plastic window. I hope I got my point across
Old Sep 2, 2009 | 06:02 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Happened to both my 87 vert and my 96 vert. Just live with it. If it is warm enough to drive with the windows open then put the top down and let the breeze ruffle your hair.
Old Sep 2, 2009 | 06:20 PM
azrocketman
If I only had hair, this would be an option.
Steve
Old Sep 2, 2009 | 06:59 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Sorry to say, live with it!
Old Sep 11, 2009 | 08:55 AM
ks5shooter's Avatar
ks5shooter
St. Jude Donor '10-'11-'12-'13
mine does the same
Old Sep 11, 2009 | 01:50 PM
Biker's Avatar
Biker
Nice to commiserate with others on this topic. I've found nothing to solve the problem. What was GM thinking? I suppose they never tested the car with the top up and windows down?
To Convertible question
