Need Help!!!
Old Sep 7, 2009 | 11:39 AM
1coolvette's Avatar
1coolvette
4th Gear
Default Need Help!!!
Twice now my 95' has faild to start. Nothing happens when you turn the key. No dash board lights, nothing. I'm assume it's a VAT's problem.
1st time it happened after several attempts it cranked. Radio and all the gauges reset.
2nd time after several un-successful attempts to start. I removed the positive cable from the battery. As soon as reconnected it the security system activated and car started.
Any ideas before I take it to the dealer?
Old Sep 7, 2009 | 12:33 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Try cleaning the pellet on the key and use a Q tip to try and clean the contacts in the switch.
