Engine leaning out
Old Sep 12, 2009 | 07:19 PM
65 fi's Avatar
65 fi
Default Engine leaning out
My son has a 383/430hp crate engine with a BBK 52mm trottle body. He is using a Accel super ram intake and long tube headers, SC-1 supercharger, MSD ignition, TPIS high flow fuel pump and 42 lb injectors. The pump is new and seems fine when driving normally and the in-line filter is fairly new. When the car revs past 3500-4000 it leans out. When the car goes into boost fuel pressure drops substanially (almost to zero). He had the car on a chassis dyno which showed a reading from the O2 sensor full of peaks and valleys. Is it possible the stock fuel line from the pre-existing small block is too restrictive? It seems that his car should be producing some serious horse power and cannot seem to reach its potential. As-a -matter-fact it was doing better without the blower.
