storage for the winter?
Old Sep 14, 2009 | 09:06 PM
RR40vette's Avatar
RR40vette
Default storage for the winter?
Winter is around the corner soon I have a few questions on storage of the vette, this will be the first wisconsin winter with the ruby corvette,
When I put it away,
1. Keep the gas tank full?
2. I don’t have a heated garage will the car be find this way?
3. Should I disconnect the battery?
4. Should I leave the window crack a little under the car cover?
5. change the oil
anything else should i may want to do?
thanks
Old Sep 14, 2009 | 09:17 PM
betyelou's Avatar
betyelou
Do a search for Winter Storage and you will see many good tips for getting your vette ready for the long sleep.
Old Sep 14, 2009 | 09:19 PM
pianoguy's Avatar
pianoguy
I store mine covered in an unheated garage, no problem. I do the following:
Wash & wax exterior, vacuum interior
Change oil & filter
Fill gas tank and add Sta-bil
Pump tires up to 45 lbs.
Place large moisture-absorbing packs in interior
Place containers of cut-up Irish Spring soap in interior and engine compartment
Stuff steel wool in exhaust tips
Connect battery to a battery tender
Old Sep 15, 2009 | 05:50 AM
RR40vette's Avatar
RR40vette
Change oil & filter
( moisture-absorbing packs ) ??
Old Sep 15, 2009 | 05:53 AM
mazdaverx7's Avatar
mazdaverx7
moisture absorbing packs keeps condensation out of the car. they are filled with hardened silica gel beads. i keep the small packs in each drawer of my tool boxes to prevent rusty tools. the soap will keep the mice out.
Old Sep 15, 2009 | 05:08 PM
Biker's Avatar
Biker
I inflate the tires to about 40 psi; fill the tank and treat with StaBil; disconnect the battery and connect it to a Battery Tender; open both windows about a quarter inch; and cover the car with a breathable cloth cover. Lastly, I say 'thanks for the fun' and walk away sadly.
Old Sep 15, 2009 | 09:59 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
After I put it in the "Cocoon" for the winter
Put it on jack stands
Inflate the tires to 40#
Every 3 weeks I start it and let it run until the fan cycles a few times. about 30 minutes
Old Sep 16, 2009 | 07:47 AM
DaveT91's Avatar
DaveT91
The only other thing Ill Add to wats already been said is, put "Bounce" Dryer sheets inside the Car and under the hood (remember to take them out inthe spring). These too keep the mice away
Old Sep 16, 2009 | 06:48 PM
Larry/car's Avatar
Larry/car
It depends on how long the car will not be operated. Mine normally only sits about two months. I have a heated garage and all I do is shut it down hot after a good run and put a battery tender on the battery. I like to have the fuel tank at less than half full. When the car is used again I fill the tank. Never had a problem.
Old Sep 16, 2009 | 08:17 PM
RLG's Avatar
RLG
here in Tulsa we only have about 90 days of "winter" so all I do is cover it , fill it up, add sta-bil to the tank and hook up the battery tender, but unless there is snow or ice I will drive it on nice winter days.
Old Sep 16, 2009 | 09:16 PM
hookedonvettes's Avatar
hookedonvettes
My routine:
-change oil & filter late fall- (on start up in spring no need for fresh oil)
-wash the car, polish/wax optional as time permits
-fill gas tank and stabilize
-park in my unheated attached garage- early to mid december
- remove battery, remove to interior heated location, place on a piece on wood rather than concrete floor, keep it charged up
-cover the car, ensure adequate critter control
- remove cover every 4 to 6 weeks, look at it wistfully and hope for early spring
-come spring- fire it up , and drive the hell out of it.
Old Sep 16, 2009 | 10:55 PM
RLG's Avatar
RLG
does the bounce dryer sheets really work?
I have not heard that. I would like to know, I will use it on the Vette and the 69 GTX and my dodge Ram that sits out in the shop.
Old Sep 16, 2009 | 11:24 PM
lostnfoundC4's Avatar
lostnfoundC4
I do the same thing but horde them when unpacking stuff. Where can you buy them?
Old Sep 17, 2009 | 01:56 AM
MK 82's Avatar
MK 82
When I put it away,
Yes
Depends
Remove the battery and keep it on a Battery Tender in a heated space.
No
5. change the oil
Can't hurt.
To storage for the winter?
