A question about weather strip
Old Sep 14, 2009 | 11:11 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Default A question about weather strip
Is the weather strip for the C4 coupe rear hatch one continuous piece or is it two pieces seamed at the corners? The reason I ask is because to day I noticed a gap at the driver's side corner right where it makes a sharp angle. Is there any way to repair it?
thanks
Old Sep 15, 2009 | 08:35 AM
LannyL81's Avatar
LannyL81
The piece around the rear glass is one piece. The corners are where it tears due to the glass opening and closing. You can try to glue it and it might hold for a short time...but the only real way to repair it is to replace it.
Easy job....a bit messy, but easy to do. Get the replacement from Wilcox Covette....avoid the cheap stuff.
Old Sep 15, 2009 | 10:22 AM
jrzvette's Avatar
jrzvette
DAYUM!!
I'll try the black ws adhesive for the time being.
To A question about weather strip
