Anti-freeze ???
Old Sep 15, 2009 | 10:18 AM
93LT1Sunshine's Avatar
93LT1Sunshine
Default Anti-freeze ???
Hi everyone I was just wondering is there a certain kind of anti-freeze that I should be using in my '93 LT1 corvette ? I find myself have to add a water mix with anti-freeze about every other week or so , to the over flow ! Just anted to make sure I'm using the right kind !! Thanks alot , ~Sunshine~
Old Sep 15, 2009 | 12:07 PM
Mr. Dude's Avatar
Mr. Dude
I use the green stuff in my 87. Be sure to buy straight antifreeze and mix it yourself as with the 50/50 mix stuff you're paying for water.
Old Sep 15, 2009 | 12:30 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I think that one is 20/80 (20% anti-freeze).
Old Sep 15, 2009 | 12:41 PM
Frankbraeside's Avatar
Frankbraeside
Default Only use green stuff
On 93 only use the green stuff. Dex Cool (yellow) will not mix with "green stuff" and clog the system. Prior owner on my 93 tried to mix yellow and green. It took many flushes to clean entire cooling system get rid of the mess it caused. I use a concentrate and 50/50 mix with water. Good luck.
Old Sep 15, 2009 | 07:19 PM
93LT1Sunshine
Thanks guy's !! I'm glad I asked !! Nothin' but the green stuff for me !! LOL ! 50/50 that is !! Thanks again !!
Old Sep 15, 2009 | 09:12 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Default Prestone for sure!
Use Prestone antifreeze/coolant and mix it 50/50 with distilled water. Believe me the distilled water will make a difference in how clean the coolant stays. Also as was already mentioned, never buy a 50/50 mix as you are paying for half water instead of coolant.
Old Sep 15, 2009 | 09:43 PM
tblt44's Avatar
tblt44
I just used prestones any color and it's green but works with all anti freeze.
I use a 75 25 mix.More anti freeze the better.
Old Sep 15, 2009 | 11:22 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Have you checked your cooling system? You shouldn't have to add to it "about every other week or so".
Old Sep 15, 2009 | 11:57 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
I use Prestone "any color" in my 95. This comes in a Yellow jug and the fluid is green in color.
If I remember correctly the GM "dex cool" is ORANGE in color and comes in a jug with an orange cap.
PS as jrzvette points out you should not have to be adding fluid to your system every other week ... get your system checked out.
Old Sep 29, 2009 | 09:11 AM
ks5shooter's Avatar
ks5shooter
St. Jude Donor '10-'11-'12-'13
Old Sep 30, 2009 | 06:33 AM
Red-Lt1's Avatar
Red-Lt1
You need to check it out. Something is wrong. Find out before you are out a ton of money.
Old Sep 30, 2009 | 12:00 PM
azrocketman's Avatar
azrocketman
1) Do not mix the green antifreeze with the orange Dex Cool. They are not compatible.
2) More antifreeze is not better. Water transfers heat better than antifreeze. A 50-50 mix generally gives the best combination of heat transfer, low temperature protection, and boil over protection.
Steve
Old Sep 30, 2009 | 12:34 PM
lt1396corvette's Avatar
lt1396corvette
More is better if you live in Alaska
Old Oct 6, 2009 | 02:25 PM
MK 82's Avatar
MK 82
Anything over a 50/50 mix is a waste of your money and lowers the cooling ability of your system.
Old Oct 6, 2009 | 02:33 PM
runner140*'s Avatar
runner140*
What ever brand and type you choose, make sure NOT to get any on your Opti or it might die.
To Anti-freeze ???
