lifting shifter solved!
Old Sep 19, 2009 | 10:17 AM
littlesk8cracker's Avatar
littlesk8cracker
Default lifting shifter solved!
if you guys remember, i bout my 94 about 2 1/2 weeks ago and posted up that the motor mounts were bad. my shifter was lifting aloottt and the whole thing would bang around if i got on it. very bad. so about 50% told me motor mounts, 50% told me c-beam. well, last night i got under to check the c-beam out. the front bolts were very loose! so i tightened them up... problem solved! now i can really get on the car, its great. would just like to thank everyone that helped me out, cause i would have never figured it out.
Old Sep 19, 2009 | 10:55 AM
VetteMed's Avatar
VetteMed
Glad it was a simple fix for you!
Old Sep 19, 2009 | 11:51 AM
Weav's Vet's Avatar
Weav's Vet
Get you some of these and that will never happen again.
Glad is was something that simple!
http://www.corvetteactioncenter.com/...php/product/27
Old Sep 19, 2009 | 11:59 AM
VetteMed's Avatar
VetteMed
One more vote for Beam Plates here -- makes life a little easier when dealing with that C-beam.
Old Sep 19, 2009 | 12:12 PM
littlesk8cracker
ya i was thinking about doing the plates, but just tightening these up was hard enough! i had alot of trouble getting to the top nuts to hold them still. id be afraid id get it off to put the plates in, then not be able to get it back on
Old Sep 19, 2009 | 09:02 PM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Thanks for posting the follow-up! We all learn from each other and it's good to know what the actual problem winds up being.
Old Sep 19, 2009 | 10:37 PM
VetteMed's Avatar
VetteMed
That's the beauty of the beam plates, it makes the job so much easier than the stock nuts. Just have to get the threads started and you're good to go!
To lifting shifter solved!
