Door Ajar
Old Sep 22, 2009 | 02:35 PM
Jbyrd43's Avatar
Jbyrd43
Default Door Ajar
I was driving in the rain today which sucked and my interior lights kept coming on, and flickering, and now are stuck on. My dash says door ajar. I have a 91 vert. Does anyone know why this is happening, i opened and shut the doors and made sure they are shut.
Old Sep 22, 2009 | 02:39 PM
GKK's Avatar
GKK
The "Door Ajar" switch needs to be replaced.
It's located on the end of each door and has a little black plunger that adjusts to the correct depth to contact the inner door frame. The plunger probably got pushed in too far and is no longer making good contact with the door frame, causing the flickering interior lights.
You can buy the door ajar switch from any of the Corvette vendors here on the forum or from the dealer.
Old Sep 22, 2009 | 03:14 PM
Jbyrd43's Avatar
Jbyrd43
I was playing with the switch and it still pushes down and when its pushed down the beeping and lights stop. But its like it doesn't get pushed down far enough when the doors shut, would it still be the switch?
Old Sep 22, 2009 | 04:32 PM
89 Vett's Avatar
89 Vett
Sounds like it's just the switch, but I thought the 'Door Ajar' light and the interior lights are triggered by seperate switches? I seem to remember one in the crook of the door and one at the end. The 'Door Ajar' light is triggered by the one at the end when the door doesn't latch well. The one in the crook of the door triggers the lights.
Old Sep 22, 2009 | 04:42 PM
jhammons01's Avatar
jhammons01
Mine did that just last month.....it was just sorta gummed up. I sprayed WD40 on it and then I pushed and allowed it to spring back out and click.....I did it over and over and all was healed.
Old Sep 22, 2009 | 06:12 PM
BlackbirdZ07's Avatar
BlackbirdZ07
Water lubricates the pin that makes contact with the body and closes the switch. When that happens, the pin gets pushed in too far and therefore the plunger doesn't get pushed in far enough to close the switch.
In the middle of the plunger on each door switch you can see the pin with a flat round head. Pry it out with a small flat blade screwdriver. It's self-adjusting, so when you close the door the first time it'll get pushed in to the right length and the switch will close.
It may well do it everytime it gets wet, so you may have to replace the switch(es) to keep it from happening. Prying the pins out should work at least until the next rain shower. You can lubricate the plunger, but DO NOT lubricate the pin.
Old Sep 22, 2009 | 06:55 PM
Jbyrd43's Avatar
Jbyrd43
Me pulling the pin out a little worked. I didn't even notice the pin was there since it was pushed in. Thanks a lot
Old Sep 22, 2009 | 09:58 PM
yaknow's Avatar
yaknow
Thanks for the info, been chacing this ghost for awhile
Old Sep 22, 2009 | 11:07 PM
GIMMESOME's Avatar
GIMMESOME
If it doesn't move and it should...WD40
If it moves and it shouldn't...duct tape.
Old Sep 23, 2009 | 01:41 PM
BlackbirdZ07
To Door Ajar
