1984-1996 Suspension Difference
Old Sep 22, 2009 | 11:59 PM
Carnut_s's Avatar
Carnut_s
Default 1984-1996 Suspension Difference
I just picked up a project truck with a C-4 front and rear suspension installed. I need to order some parts but need to know how to tell what year the suspension is. Any ideas ?
Old Sep 23, 2009 | 12:16 AM
1984 porn-mobile's Avatar
1984 porn-mobile
Well its either 84 to 87 or the other stuff after 87...............
Just a guess but I would assume that most suspension is interchangable............... Flip a coin... 86 or 88........ zr1 option will be for stiffer stuff............... swaybars and spring rate for the leaf spring............. Maybe someone else will have a more of a technical answer on determining the actual year but thats how I would be looking at it...... If your looking for ball joints and bushings almost any year should be workable...........
Old Sep 23, 2009 | 02:03 AM
rodj's Avatar
rodj
Guessing gets you nowhere
88+ rear has a thick spacer between spindle and hub to mount caliper and park brake on caliper .
84 - 87 have park brake shoes inside the rotor with a alum backing plate.
84 - 87 rear shocks have bushes both ends where as 88+ have a stud top mount.Most rear parts , springs , half shafts , hubs ,diff center ,etc interchange ; 84 - 96.
The smaller Dana 36 diff has 3 bolts across the top where the head is bolted to the batwing ; the stronger Dana 44 has two
88+ front has 2 piston calipers ; 84 - 87 has one
Nothing on the front interchanges between the two styles.
88+ is 3/4" a side wider than early.
Springs have a 3 letter code stamped in them to identify spring rate.
To 1984-1996 Suspension Difference
