Trickle charge install help
Old Sep 26, 2009 | 11:50 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Originally Posted by PLRX
I used a battery tender and the SYS light came on, it killed the battery. Now, I use it to charge the battery but I will no longer leave it connected.
Sounds like you have something else going on there.
Old Sep 27, 2009 | 01:33 AM
Gromit3860's Avatar
Gromit3860
Default Battery Tender Killed Battery
You usually get a pretty good warranty with the Battery Tender, so I would look into that.
I have never had a problem with the Soneil charger. It is not cheap, but neither was your Corvette! The peace of mind knowing that your vehicle is being kept at a proper charge without danger of damage is good enough for me! Use the cigarette lighter accessory socket for very easy attachment and you have a solution to long winter, snowy salty road days!
