Vapor locking issues
Took it on the road and I noticed it started vapor locking - what's up with that? Is there supposed to be a sheild by the filter?
Any other ideas?
Eric
I didn't think you could have vapor lock with the stock fuel injection system, since it's under so much pressure.
You might possibly have a fuel injector issue.
The WORST gasoline under 45 PSI pressure boils at 266* F While it's possible for the fuel rail to reach that temp (though not likely), as soon as you start the fuel pump, and gasoline starts circulating through the rails...FROM THE TANK, and back to tank, that possibility is over.
The pump is sitting in gasoline, IN THE TANK. How hot does the tank get? Maybe as high as 120*F on a hot summer day? Sorry, but "Vapor Lock" is not happening. The problem is caused by some other, explainable issue like a bad pump, clogged filter, etc.
As for if I think you have vapro lock, no. You have a different issue.
A "Couple minutes"?? No. It takes about 5 seconds for fuel to make it to the Throttle bodies once you turn the key on. In fact, key on, the pump runs (primes) for ~2-3 seconds. That alone is nearly enough. By the time the starter cranks the motor a turn or two, cool gas from the tank , is at the injectors, and already circulating back to tank.
CFI's are known for having questionable pumps. Throw a gauge on there, and check it; at idle and under load. Spec is 9-13 PSI. What ever you see KOEO, you should also see at WOT. If the pressure drops at any time, under any condition, you have a problem w/your fuel delivery system (filter, pump, screen, as you stated).
