engine coolant temp sensor
Old Sep 24, 2009 | 08:45 AM
jett40's Avatar
jett40
Default engine coolant temp sensor
i installed a new ect sensor which is on the water pump and now i get a SYS when reading the temp on the digital display. example: it will read 180 then it will say SYS then it will tell me the temp again.
my question is do i need to reset something after switching the sensor out with a new one ?. i already disconnected the negative cable on battery to try and resett ecm.
1993 vert
john
Old Sep 24, 2009 | 05:15 PM
Mrmatt2009's Avatar
Mrmatt2009
make sure your battery connection is good because this could trigger your sys.
Old Sep 25, 2009 | 08:33 PM
1Harley 1Vette's Avatar
1Harley 1Vette
I replaced mine whem I replaced the water pump and didn't have to do anything out of the ordinary. I did check the codes with a paper clip and did not find any codes present. I would try disconnecting the battery again and also try to pull codes.
Good Luck and let us know what you find.
To engine coolant temp sensor
